Do you want network unlock pin? Yes means you can visit this site Prounlocking.com here you can get the network unlock pin and unlock your mobile easily. If you have a blackberry mobile you can visit this site Unbblock.com here you can get the network unlock pin and unlock your mobile easily
UNBBLOCK.COM
2002 DYNA ALL incl FXDWG
Connector 7 is under the seat. It is the main harness to tail lite connector. The wires from main connector are:
2002 All DOM and INT Including FXDWG
Connector 7 pin 1 goes to tail lite 94 connector pin 2 = BW
pin 2 goes to 94 pin 1 = O/W
pin 3 goes to 94 pin 5 = V
pin 4 goes nowhere = empty
pin 5 goes to 94 pin 6 = BK
pin 6 goes to 94 pin 4 = R/Y
pin 7 goes to 94 pin 3 = BE
pin 8 goes nowhere = empty
Connectors 93, 94, 18, 19 are all in the tail lite assembly.
19 = Rt Turn pin 1 = V/BN pin 2 = BK
18 = Lt Turn pin 1 = V/BN pin 2 = BK
93 = Brake and running lites pin 1 = BE = Dom running pin 2 = O/W = HDI running pin 3 = R/Y = Brake pin 4 = BK = ground
2008 TOURING is the same as 2002 DYNA and also has connector 45 in tail lite assembly where pin 1 = BK; pin 2 = Empty; Pin 3 = BK = licence plate lamp
Horn has 2 wires BK = ground going to main harness and Y/BK going to pin 6 of connector [2A] which is
Main to interconnect harness 12-place Molex (gray) Inner fairing - leftt radio support bracket
You need What brake system front or rear??
Front signals from [31] pin one = BK = RT turn; pin 2 = BN = Rt Turn; pin 3 = BE = DOM running lite; pin 4 = BE = DOM running lite; pin 5 = V = Lt turn; pin 6 = BK = LT turn
[32] = pin one = BK; pin 2 = O/W = DOM Front Fender Tip Lite
[73] = 1 = GY/BK = Rt Aux lamp gnd; pin 2 = GY/BK = Lt Aux lamp Grnd
