Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
I have a Sony KF 60XBR800 tv and recently replaced the lamp. The tv works for about 10-15 minutes but then shuts off by itself and turns back on within a minute. We havve tried re-inserting the lamp, making sure the door is closed, and unplugging/plugging the tv. Please help!! thanks!
2 Related Answers
ladywinn
ladywinn
  • 5138 Answers
SOURCE: TV shuts down and blinks red 6 times
Lamp or Fan is going bad.Take lamp out see if it looks good if so listen/watch to see if Fan keeps runningwhen turned on if Fan stops running ,Lamp and power will not come on.!
Posted on Dec 18, 2008
Azrael SRL
  • 11800 Answers
SOURCE: i have a sony kf-60xbr800
The thumping noise is caused by the power source: it tries to start, it gets severely overstressed by a failed part and it gets shut down by its own protection system - this process repeats itself several times until the source is shut down for good.
The first part that fails in this tv is the ballast/driver for the bulb
http://www.discount-merchant.com/SONY-4422-336-02243-p/1219853.htm
i'm assuming that you have checked it before replacing the power source. If the ballast is good then the failed part will be in the rest of the components of the tv and you will have to check them, starting with the audio amplifier.
Posted on Jan 31, 2011
Sony Grand WEGA KF-60XBR800 Service Manual
Lamp/Bulb A1601-753A (XL-2000U) .
http://www.shopjimmy.com/dlplamps?tv_brands_select=Sony&tv_models=Sony+KF-60XBR800
Apr 29, 2014 | Sony Grand WEGA KF60XBR800 60" Rear...
My sony kf-60xbr800 keeps tirning off and on
If lamp has not been replaced in last 2-3 years then replace it, this tv turns off and on because of dying lamp.
Let me know if you see standby/power light flashing on tv front, this is an error code that shows some other problem instead of lamp.
Aug 01, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
My Sony Grand Wega KF-50WE610 turns on and off audio and visual
Lamp maybe the problem they only last 5,000 playing hours Mats has best Price for them
1-800-628-1118 Fisrt CK the Fans If Lamp fan quits working Lamp will shut off to protect Lamp from burning up.
Visit Encompass Parts Distrubtion they will list Parts for this Model.
Mar 22, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a Sony kf-50we620, It started having problems this week. Sometimes, not always, I turn it on, the green light flashes and the TV will eventually start but it takes over 2 minutes to start. I will...
Its symptoms of weak lamp that need to be replaced.
How old is this TV and did you replaced its lamp recently?
lamp replacement is easy and would be written in user manual. Please buy Sony original lamp for TV safety.
Thanks.
Jan 15, 2010 | Sony Grand WEGA KF-50WE620 Television
When I turn my Sony Grand Wega Kf-50XBR800 on,
This is symptom of weak lamp in TV, please replace lamp in TV and I would suggest to buy Sony original lamp for TV safety.
Lamp replacement procedure is written in user manual in details, click Sony Support if you want to download user manual copy.
Thanks.
Oct 18, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Kf-60xbr800 indicator blinks 5 times
5 indicates lamp ballast failure p/n 1-468-510-15 . but thats not always correct. sometimes the tv doesn't detect it correctly and it's just the lamp XL-2000U p/n A-1601-753-A .
Sep 28, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Turning off
Have you replaced the lamp? shut down problems come from several things but the most common is lamp current draw, thermal shut down (fan clogged), and bad ballast .I'd start with the lamp.
Jan 06, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
