Microwave Ovens Logo
Question about Kenmore Microwave Ovens
How many cubic ft. in a Kenmore microwave over stove model # 665-61612100
I need to know the cubic feet for the model?
Anonymous
Just measure the inside dimensions of the unit in inches. Get the length, width and height then use this formula: (L x W x H)/12 = Cubic Feet
Posted on Feb 26, 2015
  • Anonymous Feb 28, 2015
    The formula is not correct you should divide the total by 1728 not 12 to get cubic feet.
I need to know that the cubic size is and the wattage for this model. Thanks.
Hello friend, thank you for your post!
Based off the information you have provided you would like to know the cubic size for your Frigidaire microwave, FMT148GP. The cubic footage of this particular model is 1.4 cubic feet. Hopefully this information is helpful to you. -Matt
I need to replace microwave and don't know what size in cubic feet?
Multiply interior's height x width x depth. Ex: lets say 10 inches x 12 inches x 8 inches = 10 x 12 = 120 x 8 = 960. Divide 960 by 1728 (12 x 12 x 12) =. 56 cubic ft( point 56) just a tad more then half cubic ft.
How many cubic feet are there in a GE over the range microwave model # JEB1860dm2ww serial #RV200204L
The first two numbers indicate the cubic feet this would be a 1.8 cu ft model
WHAT IS THE CUBIC FEET OF JVM1339WB-002 GE MICROWAVE SPACE SAVER?
Determining the cubic feet of any given appliance, Microwave, Oven, Freezer or Refrigerator is quite simple.
Follow these steps.
Open the door of your microwave and measure the length, width and height in inches of the interior cavity.
Multiply the length by the width by the height using a calculator to get the total in cubic inches.
Divide the cubic inches by 1,728, which is the volume of a cubic foot. The resulting number will be your microwave's measurement in cubic feet. You can also use an online conversion calculator to simplify matters
Hope that helps
How Many cubic feet in a elite?
This is a 2.0 cu ft model. link to user manual:
http://kitchen.manualsonline.com/manuals/mfg/kenmore/721_7920.html?p=1
1helpful
How many cubic feet is a GE spacemaker model l# JVM240WL001
you must ask some vendor Online via chat with GE, they offer many Sales, and good opportunity. Get in tourch with them.
God bless you
1helpful
We have the GE JVM130H 001 microwave. I am trying to figure out what is the cubic feet capacity of this microwave. Can anyone tell me?
Hi, W/D here.
Here's an easy way to calculate your cubic feet: measure and multiply (in inches) the width X depth X height, then divide by 1728. This will give you cubic feet.
For example, if a microwave measured 18" wide X 18" deep X 12" high, it would be 3888 cubic inches; divided by 1728 (cubic inches in one cubic foot) = 2.25 cu.ft.
Best regards, --W/D--
Please take a moment to rate this solution. Thanks. --W/D--
2answers
What is the cubic feet of a model 25353614300 side by side please.
This should be a 23 cubic foot Frigidair built refrigerator. The actual dimensions usually are 22.4 cu. ft. Sears keeps changing how their model numbers read so I could be wrong. Good Luck, Appliance Specialists
Size of older GW Microwave
If you want to calculate the volume of an object and have the answer in cubic feet.
Volume=Length X Width X Height
With the dimensions you give
Volume=12.5in X 37in X 20in
Volume=9250 cubic inches
To convert 9250 cubic inches into cubic feet you need to understand that there are 1728 cubic inches in 1 cubic foot.
L X W X H = 12"X12"X12"=1728 cu in
You then multiply 9250cu in and (1/1728cu ft) Really you are dividing 9250 by 1728.
your answer is 5.35 cubic feet.
12 inches in 1 foot
144 square inches in 1 square foot
to convert you put the unit you want to keep on top of the dividend.
to conver to to feet ( randomly selecting 100 inches)
Example converting 100 inches to feet
100inches X ____1ft____ = (100/12) = 8.3 feet
12inches
or cubic inches to cubic feet
4000 cubic inches to cubic feet
4000cu in X ____1cu ft____ = ( 2.33 cu ft)
1728 cu in
if you notice that the units on top and bottom of the dividend cancel each other out leaving the numerator (top number) as your unit.
it also works in reverse
2.33 cu ft X ___1728 cu in____ = (4000 cu in)
1cu ft
Open Questions:
Top Kenmore Microwave Ovens Experts
Jaime Hernandez
Marvin
Marvin
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
