Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Tv turns off automatically only on bbc channels and comes back on
1 Related Answer
Samyfam
Samyfam
  • 379 Answers
SOURCE: No BBC channels available after retuning Sony Trinitron TV
When TV channels are moved from one frequency to another frequency that was previously used by a different channel (sorry, but there's no simple way of saying that !) as has happened recently in th UK, some digital TVs and digiboxes struggle to sort the channel list out properly and channels can go missing as you describe.
If your equipment has the option to delete all currently stored channels (normally in the tuning menu options) then do so and then do a full re-tune.
Sometimes, this solves the problem as the equipment is no longer aware of any previous use of a frequency and just loads every channel it finds.
If this doesnt work, or your equipment doesnt have the option, then there is normally the option soemwhere in the menus to retore the item to "factory defaults/configuration". This will clear all previously stored channels and after a full re-tune your missing chanels should be there. However, any other configuration changes you previously made, e.g picture size, output type (RGB/NSCT/etc), etc will be lost and you'll need to set these again.
NB. some regions of the country have lost some channels temporarily now until after the switch over programme completes at the end of 2012. If you visit the Freeview website, this will tell you if your area is affected.
Posted on Nov 07, 2009
How do I unlock bbc 1 channel on my fox sat-hdr
You can't, you can only view the BBC content in the UK, or use BBC World News at a fee. It is UK national broadcasting company and people in the UK pay an annual license to watch it. For that reason, it is not given to people in other countries for free. There will be a charge for it, or it will be in a higher paid package. I am British :>)
TV Guide - Foxtel
https://www.foxtel.com.au/got/whats-on/tv-guide.html/channel/BBC-First/BSF
117 BBC First. ON NOW. Started 8:30pm. ***** in Paradise. S5 , Ep1 , Episode 1 (M). ***** in Paradise Image. 9:35pm. Trust Me. S1 , Ep3 , Episode 3 (M). Trust Me Image. 10:30pm. Tin Star. S1 , Ep2 , The Kid (MA15+). Tin Star Image. 11:20pm. Love, Lies & Records. S1 , Ep1 , Episode 1 (M). Love, Lies & Records Image.
BBC First ' Foxtel.com.au
https://www.foxtel.com.au/tv-guide/channel/BBC-First/BSF 117 BBC First. ON NOW. Started 7:30pm. ***** in Paradise. S5 , Ep1 , Episode 1 (M). ***** in Paradise Image. 8:30pm. Tin Star. S1 , Ep3 , Comfort Of Strangers (MA15+). Tin Star Image. 9:20pm. Taboo. S1 , Ep2 , Episode 2 (MA15+). Taboo Image. 10:25pm. Guerrilla. S1 , Ep1 , Episode 1 (MA15+). Guerrilla Image.
BBC First ' Channels ' BBC Worldwide Australia
www.bbcaustralia.com/channels/first/ BBC First is the home of premium, original British drama on Foxtel, Fetch TV and Flip TV.
Mar 27, 2018 | Televison & Video
Screen freezes BBC Channels only. Unfreeze by switching off TV. Handset and TVs buttons fail to work. Minutes laterscreen freezes again. No problem with non BBC channels
turning tv off and on wont make it better
you on roof antenna or a cable tv
if antenna only
you may be in weak signal area
or a new construction site or buildings deflecting the signal
antenna problem or needs upgrade
go back to TV set up and re-tune tv to bbc if possible
if it freezes then you know its an interrupted signal
Mar 26, 2017 | Televison & Video
On my Techwood it as built in freeview but every other channel is right except bbc1 and bbc2 both channels say bbc wales,How do i get them back to bbc1 and bbc2 please PLEASE HELP.THANK YOU.
What you need to do is retune the TV, but when it is finished look at the regional settings. Or if the regional option is available before retuning, retune selecting your area so then you get normal BBC channels. It's likely that at the moment the channels for BBC are located at the very top end of the channel list say? - channel 800+.
You are clearly picking up signals from many transmitters. With regional settings you can change it to the area you live in.
But you will have to take into account how good your aerial is. Otherwise the signal quality will not be good on same transmitters. So the set may only suggest those with the best quality signals.
ITV stations might also change.
When done it will move the channels you mention to the top end of the guide, to 800+.
Note many HD channels have no regional options. For example here in Yorkshire we only get ITV Granada and not Yorkshire TV on the HD channel for ITV1. And BBC1HD does not show any programmes when local news comes on.
Jul 02, 2016 | Televison & Video
How do I get the BBC channels back
Sounds like you need to check if the tv is set to the right region.as BBC is region orientated.
Dec 08, 2014 | Televison & Video
How to tune a tv
Try the TV in a location where one of the other TVs works. That will show if it's a TV or a cabling issue.
It's entirely possible you have too much power in the aerial signal system. The mux carrying the BBC channels will be one of the strongest at each TV transmitter across the UK. This is because something like 96% of the UK mainland population must be able to receive at least the BBC and main commercial channels to fulfill the broadcasting requirements. Your old TV might not have been so sensitive. The new TV might be more sensitive. So the signal is overwhelming the digital tuner.
Try a variable attenuator. This will give you a power control to reduce the signal as it comes in the back of the new TV without upsetting the other TVs. The MA1620 on this page is perfect for this. http://www.satcure.co.uk/accs/page15a.htm
Splitters amplified splitters and attenuators
Sep 06, 2014 | Televison & Video
Tv will not turn over from bbc to other stations
Are the other stations tuned in. If the TV is stuck only on the BBC stations then it suggests it has only picked up the most powerful channel group, which is the BBC mux.
Sep 04, 2014 | Televison & Video
Have just moved house .....have retuned tv ....but cant get any BBC channels
Automatic scan cannot detect the BBC channels, possibly because they are too weak in your new location. It should be possible to add channels manually by using your remote. The setup function of your TV may give you the option of adding channels manually
Oct 14, 2012 | Grundig Televison & Video
After retune no bbc 1 2 bbc news channels tv with
Sounds like you haven't retuned the set correctly. Use the factory settings/ default setting if poss. Look out for too much signal if you are on a booster.
Nov 06, 2009 | Pace Televison & Video
No BBC 1 or 2 after digital switchover.
I have the same box and re-tuned mine with the same results as you.However i discovered that the NEW BBC channels were on the channel guide list starting at channel 800
May 07, 2009 | Televison & Video
ITD 58, 59, 60, 61
press info button on the remote then goto tuning on the blue screen menu. say yes to auto tune then save.
Jul 28, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
447 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
