SOURCE: Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
SOURCE: I seem to be haveing
Digital watches all work from a memory chip on the movement. The most common problem is the memory is filled or corrupted when you cannot seem to re-set them. In most styles, pressing and holding all the set buttons in at the same time for three or four seconds can fix this error. The dial will clear and the time and alarms must then be reset. If not you may need to have a watch technician use the AC button inside the case on the movement. He will need to use a metal tweezers and touch the + side of the battery to the AC contact point on the movement.
SOURCE: Help! I need instruction manual for Fossil watch
If you go to www.fossil.com you can find the manuals for most of their watches.
SOURCE: Time change Fossil JR 9120
i already found one link with all Fossil manuals.
Thank´s for your support.
