Question about Stihl TS420
My stihl ts420 muffler screws won't tighten - Stihl TS420
Plink-plonk
  • Stihl Master
  • 1,807 Answers
Possible over tightened and cross threaded
Posted on Mar 07, 2015
Still ts420 concrete saw fuel line placement?
its a stihl chainsaw motor adapted into a concrete saw
Stihl Ts420 Parts
shoudnt have to take too much apart
take off air filter cover to see the carby
Apr 30, 2017 | Garden
ADJUSTING HIGH AND LOW ON A CARB FOR A STIHL FS 45 WEED EATER
Hi..in general i always set the high and low screws at 2 turns out from a complete stop..and please dont tighten the screws too tight..it will bend the needles...I think it will..or should run at them settings...as far as the gas out of the engine..it is or has a problem with the carb...did you remove the carb...? Also try starting it with only starting fluid for a very short time..this is how I check to see if all else is ok..spray it in the carb in take...
May 05, 2016 | Stihl Garden
Could someone tell me the difference between a Stihl TS410 and a TS420?
maybe here. http://www.stihlusa.com/WebContent/CMSFileLibrary/InstructionManuals/STIHL-TS-410-420-Owners-Instruction-Manual.pdf
Mar 17, 2016 | Stihl Saws
Why Do I Not Have Any Spark From The Ignition Module When Spark Plug is in The Cylinder
Search Results
    Stihl TS400 / TS420 Ignition Module Repair - YouTube
    ? 7:06
    https://www.youtube.com/watch?v=AvPv88SELXs
    May 1, 2011 - Uploaded by donyboy73
    Learn HOW TO REPLACE The Ignition Module in your StihlTS400 / TS420 ... I have a homelite 33cc Ranger it has no sparkat the plug but if I put a ... a good spark and there is fuel getting into the cylinder head also what are ...
    All comments on Stihl TS400 / TS420 Ignition Module Repair
    https://www.youtube.com/all_comments?v=AvPv88SELXs&lc...
    Donyboy73, I hava a Stihl TS 420 and just replaced the pull rope (not sure what's ... a good spark and there is fuel getting into the cylinder head also what are your ..... Hi mate, i have no spark to my plug?? i have tried a brand new plug and still ...
    Small Engine Ignition: Ignition Wires, Chainsaw Spark Plugs ...
    www.hlsproparts.com/small-engine-ignition-parts-s/149.htm
    66 results - HL Supply has the small engine ignition parts that will get your ... parts right here: ignition wires, chainsaw spark plugs, ignition coil sets, ... Please don't hesitate to contact us if you have any questions. ... Stihl TS400 (3-bolt old style), TS460 ignition coil with wire and cap ... Fits: Stihl TS410 and TS420 cut off saws
Feb 08, 2016 | Stihl TS420
Stihl saw cuts out when machine is tilted forward on ts410 anybody else have this problem
Fuel pick up will be your problem. Buy new fuel filter and fuel line from in tank to carby. Most likely a split in the fuel line in-tank
Feb 13, 2014 | Stihl Ts410 Ts420 Cut Off Saw Piston Kit...
Stihl saw runs but won't idle.
The paper pumps get stiff and do not pump fuel very well. It's the new Ethanol gas that is the Carb Killers. You need a rebuild kit not just disassemble and clean.
You have IDLE ADJUST Low Speed adjust and High speed adjust. Low and High speed adjust have nothing to do with Idle.
Oct 11, 2012 | Stihl 044 046 Ms440 Chainsaw Muffler
Stihl madel ts420 how to change air filter
There are 4 torx screws on the black back cover. Here is the owners manual. It is explained on page 33.
Stihl TS420 owners manual
Jun 22, 2012 | Saws
Tension screw won't tighten the chain on a Stihl MS660
remove the cover and look to see if the tab is broken off
Apr 14, 2012 | Stihl Models 064, 066, Ms640, Ms660
Stihl TS420 Logo
229 people viewed this question
Top Stihl Garden Experts
ray gallant
Thomas Perkins
Thomas Perkins
bryan st
Are you a Stihl Garden Expert? Answer questions, earn points and help others
