SOURCE: suddenly my new samsung corby
u r mobile go to application settings-->call-->all calls--->>
show my number-->> set to by network..
Hope its solve u r issue
Sundar from vellore
SOURCE: Nokia E71 text message notification icon disappeared
I had the same problem, and the reason is that you have to much sms (usually >2000). You have to delete unnecessary ones, go to enabled applications, uncheck message notification, go back to the home screen, and go to enabled applications to check message notification again. The messa ge notification will display again
SOURCE: ENV CAN NOT MAKE or receive text or calls
try to reset your phone back to default by going to your menu then going to settings and tools then to phone settings then down to security type in your password it might be your last 4 of your phone number then to reset default
SOURCE: My phone won't send/receive calls or txts. NO SERVICE
what you need to tell the service provider is that to delete the vLR on they network then add it again
You can format your Nokia N70 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option
Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YES
