I recently had the printer set up to print A5 sheets. I now wish to set it back to print A4 sheets to normal full page portrait orientation.
When you are in the application that you are going to print from. Go to the menu bar, click on File - Page Setup. Here you should be able to change the paper size you wish to print out in. If you want to set the paper size by default to A4, then you will need to (Windows7) click on the Start button - Devices and Printers, select the printer that you want to change the paper size, right click on the printer - Printer Preferences, a dialog box appears, select the paper size you want in the paper size drop down list, click - Apply - OK. This should then have set the paper size to A4 by default.
