Question about Samsung SCX 4623F - Multifunction fax / copier / prin - SCX-4623F
I HAVE A SAMSUNG PRINTER SCX-4623 THE MESSAGE KEEPS ON SAYING DOOR OPEN CLOSE DOOR , TRIED EVERYTHING BUT NOTHING WORKS
NOTHING WANTS TO WORK THE MESSAGE JUST KEEP ON SAYING OPEN DOOR CLOSE DOOR, WE TRIED EVERYTHING BUT NOTHING WORKS
sahoo_sanjay
    Master:
  • Samsung Master
  • 553 Answers
Dear
The front door right side there is a lever found when it is opened the lever should close the micro switch inside and the door is locked with another short lock (near the long lever). If door lock broken then the micro switch push the lever and door not closed.
the basic problem with the micro switch and related mechanical alignment.
Thanks.
Posted on Feb 26, 2015
I have a Samsung SCX 4623 that keeps saying door open close it can anyone assist please
You are need to removal the covers and verify or change the microintrerupter.
Nov 23, 2017 | Samsung Office Equipment & Supplies
Paper Jam 0 , OPEN/Close Door Message Samsung SCX4100
seems as if the motor responsible for taking in the paper has stopped working and may need to be replaced
Dec 26, 2016 | Samsung SCX-4100 All-In-One Laser Printer
What could be the solution of door open, close it on samsung scx 4623 w printer?
This is common. Check the right side of the front door. It will not be flush with the main case. Just give it a wack. it will work then.
Nov 28, 2015 | Samsung SCX 4623F - multifunction fax /...
My Samsung SCX-4623 F/X when and faxing has several. top to bottom lines
If you are getting lines on the faxes you send it means that the glass of the scanner is dirty. Best method to clean the glass is rubbing alcohol and a soft cloth. The alcohol will remove adhesives and white out better than glass cleaner. You may need to look closely because a small amount of adhesive will distort the scans and cause lines and may not be obvious unless inspected very carefully.
Jan 02, 2015 | Samsung Office Equipment & Supplies
My printer is delaying a message of front or rear cover open what should i do?
at back side there is a door at the print delivery point. in door closing position it press a black lever in the middle of the door. it is not pressing the lever. check the door lever .
Oct 01, 2012 | Samsung SCX 4521F All-In-One Laser Printer
Samsung CLX-3185
Hi
Have you checked the cartridges access door?
If so,try disconnecting the printer and leaving it for a long period [like 1hr] before connecting again.
Feb 28, 2012 | Samsung CLX3185 AllInOne Laser Printer
DOOR OPEN ERROR MESSAGE SHOWING ON SAMSUNG SCX-4725FN PRINTER BUT THE DOOR IS CLOSED
Hi there remove the cartridge and clean the internal part. Then insert the ink cartridge and try. If you face same problem then reset the Printer and turn off for 5 minutes. Now again turn on and let me know the result.
Jan 21, 2011 | Samsung SCX-4725FN All-In-One Laser...
Samsung manuel for SCX-4623
Hi
Please click on the following link to get the manual
Manual for Samsung SCX 4623
I hope it works for you..
All the best!!
Regards
Dec 31, 2010 | Office Equipment & Supplies
Samsung SCX 4623F - Multifunction  fax / copier / prin - SCX-4623F Logo
364 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
