Question about Samsung SCX 4623F - Multifunction fax / copier / prin - SCX-4623F
I have a samsung fax scx 4623f it keeps on indicating printing
sahoo_sanjay
    Master:
  • Samsung Master
  • 553 Answers
Dear
Pl. update the firmware. else replace the main PBA.
Thanks.
Posted on Feb 26, 2015
Cants printing ..when start up show this massege "warming up please wait"
The fuser is not warming up. You will need a new one. Not easy to fit so best have an engineer do it.
Dec 09, 2015 | Samsung SCX 4623F - multifunction fax /...
What could be the solution of door open, close it on samsung scx 4623 w printer?
This is common. Check the right side of the front door. It will not be flush with the main case. Just give it a wack. it will work then.
Nov 28, 2015 | Samsung SCX 4623F - multifunction fax /...
I HAVE A SAMSUNG PRINTER SCX-4623 THE MESSAGE KEEPS ON SAYING DOOR OPEN CLOSE DOOR , TRIED EVERYTHING BUT NOTHING WORKS
Dear
The front door right side there is a lever found when it is opened the lever should close the micro switch inside and the door is locked with another short lock (near the long lever). If door lock broken then the micro switch push the lever and door not closed.
the basic problem with the micro switch and related mechanical alignment.
Thanks.
Feb 26, 2015 | Samsung SCX 4623F - Multifunction fax /...
Erro #04-001
The scanner part of the printer is messed up. HP says "LSU error: #04-001. Please turn off then on." LSU = Laser Scanning Unit.
Oct 07, 2014 | Samsung SCX 4623F - multifunction fax /...
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
Cant get pc fax to work scx-4623f. Manual faxes work fine, dial tone fine. Have tried Samsung SmarThru4, but there is no provision for faxes in this window - it also doesn't give me this model in the drop...
you should install the fax utility from SAMSUNG
http://www.samsung.com/us/support/downloads/SCX-4623F/XAA
got to the Software tab page and download the file :
PCFax_V1.05.13.exe
after restarting the pc it should work.
Jan 21, 2011 | Samsung SCX4623F Laser All-in-One Printer
How to reset toner ,Samsung SCX-4623F
we have reset software for scx 4623f printer. www.nakshatraworld.com
May 13, 2010 | Samsung SCX-4300 Monochrome Laser...
Samsung SCX 4623F - Multifunction  fax / copier / prin - SCX-4623F Logo
120 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
