Important: It is recommended to take a backup of all the necessary data you have on your C: drive before you format it. Formatting the drive will erase everything on it.
The steps to format hard drive can vary depending upon which version of Windows you are using. You can refer to the following links for instructions:
For Windows 8 / 8.1:
http://pcsupport.about.com/od/windows-8/fl/format-hard-drive-windows-8.htm
For Windows 7 / Vista:
http://windows.microsoft.com/en-in/windows/create-format-hard-disk-partition#create-format-hard-disk-partition=windows-7
GuruAid.com
Below is Microsofts solution to your error. Reload the OS with a Microsoft CD format it completely not the fast format option reload from sctratch. If you have no CDrom use an external.
Systems hard disk drive has FAT32 file system. Computer hard disk drive has INT-13 extensions with a system-ID type of 0C in the partition table The heads value in the FAT32 BIOS Pattern Block (BPB) is inaccurate.
To resolve the error message "NTLDR is Missing" follow the below steps: Boot the computer with a Windows 95 or Windows 98 Startup diskette or another bootable diskette with sys.com on it.
At the A:\> prompt type: sys c: <press enter> After pressing enter you should receive the prompt "System Transferred". Once the file system has been transferred reboot the computer without the diskette and attempt to reproduce the error.
