Question about Kohler 20resa 20kw Home Emergency Backup Generator
Have generator showing emergency stop code and will not start.
Traced out emergency stop wires by manual and everything looked good. Tried to reset code. Original installer did not have 120 volts ran to the generator. After running 120 volts to generator tried resetting faults. Codes will not reset and generator will not start
Posted by Shannon Holden on
Bill Boyd
    Top Expert:
  • Kohler Master
  • 53,814 Answers
There are too emergency stop sensors on generators
one is over load
the other is low oil level in the sump (Low oil pressure)
That sensor is known to trigger and activate the emergency stop so check it out after you check the oil level in the sump
Posted on May 12, 2015
3 Related Answers
Anonymous
  • 37 Answers
SOURCE: When I try to start my generator the code oc comes
Check battery volatge while you are cranking engine if voltage drops below 9 vdc you have a bad battery. If it doesn't you probable have a bad starting solenoid or a bad ground at the starting solenoid.
Posted on Nov 18, 2009
Sheldon Dedek
  • 909 Answers
SOURCE: 1975, 7.5 Kohler marine genset, runs only with the reset depresed
Can't search for a manual without model, type, serial, etc numbers...
A few things to take a look at:
1) Oil level / pressure sending unit. This is normally bypassed as long as the start switch is pressed. When engine starts, and switch is released, engine will die if sending unit is defective, or you are low on oil.
2) Exhaust temperature sensors. Older units were notorious for burning these up.
3) Cooling Water Temperature sensor. These cause trouble often, but mostly due to water pump impeller being eaten away by galvanic action and not able to pump water as effecively. End result is water temp higher than normal, which trips the switch, which kills the engine.
4) Alternator (generator) output not as it should. If output doesn't rise to proper level within a few seconds of engine start, the engine will be shut down.
5) Choke not working as it should
6) Bad fuel, bad fuel pump, clogged fuel filter.
Posted on Jun 12, 2010
Wayne Holden
  • 512 Answers
SOURCE: What is the most likely cause of an Auxiliary Fault on a Kohler Generator (Model 30RZ62)?
Problem solved by poster. good work!
Posted on Oct 08, 2012
How can I reset the "programmed exercise mode" on my Kohler 12 RES generator
You will likely need to reference your instruction manual for that specific control panel.
Aug 07, 2016 | Kohler 12 kW Emergency Power System -...
Onan genarator will not crank
If it wont crank, check to see if the solenoid on the starter pulls in, the starter and solenoid are one unit, it sounds like an internal starter contact, if you have 12V going to it. Assuming the battery is good. When you press and hold the stop button does the fuel pump pump prime? if so control board has power
Mar 24, 2014 | Onan Generator, 6500W, LP Vapor
2002 chevy silverado 5.3L 2WD wont crank ,diagnostic tool read code C0226,could this stop it from starting?
How did you find out the code? A good scranner if you no how to use it (Properly) Will all so show you what sensor detected the problem, End give you a idea what to look for,
Nov 07, 2012 | Cars & Trucks
How to reset FAIL TO START(over crank)?
Over crank is just that too much cranking with a filed to start. Plese check gas pressure and for voltage on the fuel shut off solenoid
Aug 16, 2012 | Kohler 12 kW Emergency Power System -...
Generac 20,000kW Standby generator doesn't start shows message STOP ALARM OVERCRANKED
Overcrank means that it tried to start and couldn't. It will go through 5 crank cycles and then stop with this alarm. Switch to off, hit enter to clear fault and then try to start in manual. Check to make sure you have fuel and pressure is 11 to 14 in WC.
Jun 21, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
My Kohler Model 17RES threw an Overspeed Shutdown code. I have been unable to reset the system. It makes a short "chattering" sound around the circuit board area when I try to manually switch the...
The chattering sound is the stepper motor trying to cycle. Check to make sure there is no interference, move the throttle linkage by hand back and forth fully as sometimes the 17, 18, and 20 butterfly valve sticks on the carburetor gasket. If this happens, remove the gasket and use a file to put a good bevel (45 degree angle) in it to stop it from hitting. Thats all it takes.
Jul 23, 2011 | Kohler 12 kW Emergency Power System -...
Generator won't start. Screen showing OC.
OC means OVERCRANK safety circuit stopped the auto start-up so you wouldn't burn up the starter. There is a reason the generator didn't start. Low battery, not enough fuel pressure, clogged air filter, bad starter... You just have to eliminate as many as you can visually. Rebooting the generator should clear the OC condition and you can try to start it manually.
Oct 11, 2010 | Kohler 12 kW Emergency Power System -...
Code UU
Here is the code explained direct from Kohler's manual. I'd disconnect the generator load first.
UU Undervoltage Shutdown occurs if the voltage falls below 80% of the nominal system voltage for more than seconds. Check wiring and connections.
Reduce the load and restart the generator set. —
Check wiring and Check controller configuration, system voltage
and frequency (parameter UU).
Check AC voltage and adjust, if necessary. 5.7
Replace the SCR module and test voltage again. 4.9
Separately excite unit. 5.2
Check stator continuity
See web site for manual :http://www.kohlerpower.com/onlinecatalog/pdf/tp6196.pdf
Jul 11, 2010 | Kohler 12 kW Emergency Power System -...
What does over crank mean
Means that the engine has turned over for too long without starting. It times out to protect the starter and battery wiring.
May 22, 2010 | Kohler 12 kW Emergency Power System -...
Check engine light will not turn off '99 Ford zx2
Looks like you have tried everything to turn off the check engine light. However, did you find out the error code for this? Until you resolve the issue, the light will keep coming back. You need to get diagnostics done
You can save some money by checking a new website http://prundo.com/ for free coupons for check engine light!
Mar 11, 2009 | 2000 Ford Escort
Kohler 20resa 20kw Home Emergency Backup Generator Logo
577 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Tim Venetis
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
