Question about Canon PIXMA MG5220 Wireless Photo All-in-One Inkjet Printer
How do i Print from my lg pad?
I leed to print a doce from my LG PAD
Posted by cheryl brand on
2 Related Answers
Joed911
JDTec
  • 4338 Answers
SOURCE: i9900 printer has error 5B00 & won't print
You may need to change the ink absorbers. But try resetting the printer:
Canon I series service mode
1. Start with printer OFF
2. Hold down RESUME and then press and hold down POWER Button.
3. Release the RESUME but continue to hold down the power button
4. Press the RESUME twice, then release POWER button.
Now you have put the printer in Service Mode so it will accept Service commands. Here is the list of Service commands;
A. Press the Resume button once = Print Service test print
B. Press the Resume button twice = Print EEprom data sheet
C. Press the Resume button Three = Initialize the EEprom
D. Press the Resume button Four = Clear Waste INk Counter
E. Press the Resume button Five = Change Destination settings
F. Press the Resume button Six = Head Refreshing (Cleaning)
G. Press the Resume buttom Seven, Eight, Nine, = Not used
H. Press the Resume button Ten = Return to selection Menu
To EXECUTE anyone of the above commands you "MUST Press the Power button one time. Then the function will be executed. After that function has been executed the printer will REMAIN in Service Mode,.. waiting for another command. You can only execute one command at a time. If you are through with all the commands you want to do, just press the power buttom one more time and it will turn the printer off and you will be out of Service Mode. One more note. When you get the printer into Service MOde and it is ready to accept a command, the green light will be on and steady. As you issue a command by pressing the resume button, it will alternate the color from green to orange with each press of the resume button. Remember, if you issue either one of the commands to force a print make sure you have paper installed.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jan 14, 2009
Joed911
JDTec
  • 4338 Answers
SOURCE: The message says "print absorber
You can reset the error msg, but eventually, you will have to change the pads.
How to clear E27 Waste ink absorber full
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times
while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)
Note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5.Turn off the printer.( it must be turn off) then turn it on again
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Posted on Dec 21, 2010
2answers
Want to clear out all my stuff to give my LG tablet away how do i do that
The model number LGV498, the LG G Pad II 8.0 design is similar to its predecessor. However, the tablet is seen featuring full-size USB port, which can be used to connect with portable drives, keyboards, and gaming controllers, apart from being used to charge other devices as well.
This tablet comes with a slimmer capacitive stylus with 3.5mm width. Besides a support for an external storage via microSD card (up to 128GB), the LG G Pad II 8.0 houses the company's own LG-QPair 2.0 app, Microsoft Office apps and Quick Memo+ feature among others. The KnockON feature is also included.
As for the specifications, the Android 5.0 Lollipop-based LG G Pad II 8.0 tablet equips an 8-inch WXGA (1280x800 pixels) resolution IPS display like the first-gen G Pad 8.0, and is powered by a 1.2GHz quad-core Qualcomm Snapdragon 400 processor, clubbed with 1.5GB RAM, which is a slight bump from the previous generation's 1GB.
The LG G Pad II 8.0 includes an inbuilt 32GB of eMMC storage, along with Bluetooth 4.0, GPS and Wi-Fi connectivity options. Measuring 210.8x124.2x8.95mm, the tablet weighs 347 grams and is backed by the same 4200mAh battery for 10 hours+ of use. Hope this honest review help in your decision to this amazing LG tablet Amazon com LG Pad 8 0 16GB 2nd Gen GSM Unlocked by AT Wi Fi Android Tablet...
Our lg stainless steel overthe range microwave oven will not start. When pressing start only says power 100
The touch pad could be the problem. Touch pads are notorious for going bade. the door interlock switches could also be a problem. Check to see if all the pads work if they do it could be just the start pad that is bad.
I have never heard of replacing ink absorber pad? My printed has stopped because it says the absorber pad is almost full. Where can I buy, how do I fix
When you select clean print head the ink that is pushed through it is collected by an absorbent pad directly under the print head This pad can be removed, washed with water and reinstalled after it dries.
Cannot print from the note pad
You need to make sure your note pad is not too (thick) and also
that it is the correct size of paper and not too small,(tip) sometimes small sheet can be attached to full size sheet to enable printer to print.
I have an lg tritan and I don't like how my phone vibrates. Is there any way I can change the vibration pattern on my phone?
The vibrate is set by the phone and don't believe they changed But if the can is b in the hidden menu LG Tritan Information Menu a. From the phone dial pad dial b. #help*help (#4357*4357) LG Tritan Feature Menu a. From the phone dial pad dial b. ##Feature (##3328873) LG Tritan Service Menu a. From the phone dial pad dial b. ##LGSERVICEMENU (##5473784236368) c. Service code  000000 LG Tritan Programming Menu a. From the phone dial pad dial b. ##PROGRAM840 (##7764726840) c. Service code  000000
LG shine key pad is locked
just call cumstumer service and they can tell u what ur keypad password is or click the unlock on ur phone
TOUCH PAD ON MY LG VU QUIT WORKING
You need to replace touch pad. Parts cost around $25. Fairly easy to replace. Once you see it you will know how to replace, Go on ebay and put in lg vu touch screen and you should pull up parts for your phone. Or just google lg vu replacement touch.
2answers
No print on paper
there is a pad on the solenoid, where it contacts the printhammer. this pad gets old and just falls apart. this will need to be taken to a repair shop to have the pad or solenoid replaced, or there is an adjustment screw that can be used to take up the slack caused by the missing pad. the printhead must be taken out of the machine to make this adjustment.
Lg key pad not working
ur key pad domy is damaged so change it quickly
Canon PIXMA MG5220 Wireless Photo All-in-One Inkjet Printer Logo
Top Canon Cameras Experts
old marine
old marine
Ekse
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
