Question about Dell W4200 42 in. HD-Ready Plasma Television
Dell 42inch plasma tv
Took it to local shop and they charged $135.00 to tell me that it needs an X board and a Y board? So they say they can fix it for $850.00 I phoned Dell and the parts each cost $18.99 . My question is: should it really cost me that much to get these 2 boards and more importantly is this something that i could maybe put in myself? Please help i am about to throw the tv out of the door and forget i ever heard the name Dell.
Posted by debsinva on
Anonymous
I am no expert but if the board comes already all assembled and you are capable of doing the remove and replace deal i think you hould go for it yourself. Worst case, you can spend 850. get a nice lcd. Maybe even less now
Posted on Jun 24, 2008
Lost picture on plasma tv
Check the power board for any domed capacitors. Replace them. If this does not fix Replace the power board. You can check the voltages from the power board. they are labeled. VS and VA voltages are the panel voltages.
Mar 25, 2010 | Televison & Video
I have a dell 50' plasma tv when turned on does nothing. no audio or screen display. dell tells me $1500 for shipping or s.o.l. they know there is a problem but hope custs dont complain. help
If the TV is under warranty, give them hell. Shouldn't pay more than the TV is worth for shipping, any less a dime.
If not under warranty, best to have a TV tech to come to your home to diagnose the problem. Depending on where you live, independent TV repair shop will charge about $100 for the diagnoses service. Common things that go bad for plasma TVs is the Power Supply Board or the Y buffer/main parts. Basically, cheaper to have someone come to you.
Mar 04, 2010 | Dell W5001C 50 in. Plasma HDTV
How do i fix a Blackout problem with 42inch plasma tevion tv? Or is there a firmware available to fix this problem.
Not firmware prob,95% of the time it ur main video backlight board it dead need it replaced.10% of the time it the power prob.must replaced the power supply board.
Oct 22, 2009 | Televison & Video
50 inch dell plasma tv has audio but no video
the problem was the y-sus board, i had a local tv repair shop diagnos that much for me. although, he couldn't fix it i did some research and found a company in california, itritek.com, who could. you send him the y-sus board and the two buffer boards and he not only repairs them but he upgrades them. apparently the y-sus board gets too much heat and eventually goes out, sometimes the buffer boards are affected too. itritek.com replaces the components on the y-sus board with better parts which are more heat resistent. i believe this will help you with your problem. let me know...good luck.
Jan 17, 2009 | Dell W5001C 50 in. Plasma HDTV
42 in dell plasma, no picture, sound works fine
if i tell you how i fixed it can i charge you?
Sep 22, 2008 | Dell W5001C 50 in. Plasma HDTV
Dell w4201c hdtv plasma tv BLACK SCREEN, LOGO FADES OUT, SOUND REMIANS, HELPPPPPPP
Jul 12, 2008 | Dell W4201C 42 in. Plasma HDTV
Is Dell W4200HD Y-Main board and Dell W4201C HD Y-Main board compatible
The port locations do not seem to line up the same so I'm pretty sure they are not interchangeable
http://support.dell.com/support/edocs/systems/w4201c/om/OM.pdf
http://support.dell.com/support/edocs/systems/W4200/W4200UG.pdf
It can be worked on by a local TV repair, then TV was made for Dell by Philips
Jun 12, 2008 | Dell W4201C 42 in. Plasma HDTV
LG 42INCH PLASMA TV BLANK SCREEN
Open the back cover and check the fuses on Y Sus Board and X Sus Board. If you can find a blown fuse, just replace that board and your problem will be fixed.
Feb 23, 2008 | LG RU-42PX10 42 in. HD-Ready Plasma...
Lg 42inch plasma
same thing I have a 42" plasma...screen went black but I still have audio. I heard a loud pop. What is the problem? Do I need to buy a part and repair or a new tv.
Oct 05, 2007 | Televison & Video
Dell W4200 42 in. HD-Ready Plasma Television Logo
133 people viewed this question
Top Dell Televison & Video Experts
CoppellTVRepair.com
Marvin
Marvin
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
