Are you looking to switch out the motherboard or just the processor? If you find a compatible processor you could switch them out, finding a new motherboard would be much harder though.
The compatibility isn't with the memory, it's with the motherboard and its chipset. In your case the motherboard is a FIC AM-37 which has an VIA KM266A chipset - an extremely old chipset . The only processors accepted are AMD Athlon XP of the first generation of which you already have the fastest version
http://en.wikipedia.org/wiki/AMD_Athlon(tm)_XP_3200%2B#Athlon_XP_.22Palomino.22_.28Model_6.2C_180_nm.29 So no, it's not possible to upgrade it. You will have to buy another motherboard-processor combo.
Confirm your motherboard's compatibility with the Intel CPU you want to install. Motherboards typically only support one type of CPU slot, so purchase an Intel processor that is compatible with that slot.
Ensuring your processor and motherboard are compatible is vital when choosing parts to build your own computer system. If they are both the same socket type, they will most likely work together.
Brands There are a plethora of motherboard manufacturers, but only two main processor manufacturers: AMD and Intel. Every motherboard, regardless of manufacturer, has a socket that will accept a processor.
Intel Common Intel socket types include LGA775, LGA1156 and LGA1366. Older models include PGA370, PGA423 and Socket 479.
Your motherboard and processor will be generally compatible if their socket types match. ... Intel Core 2 Quad Q9650 Processor Compatible Motherboards
Hope this will help you and please don't forget to rate me. Thanks for using FixYa
For RAM info, go to www.crucial.com and run the system scanner. For the MB you will need the mfg model number to research it on their website. Compatible processors are subject to the slot type that the MB accepts.
You did an awful lot of work to write this question. If you will go back to the HP site, you can find full specifications for your computer and what upgrade paths are available, straight from the horses mouth, so to say. If a upgrade path is listed or indicated, you can follow it. If there is no path, you can't follow it. Simple.
While there may be some processor upgradability, my advice is keep it stock. You have the stock parts - they are suppose to work together. The best and cheapest upgrade I will recommend is put in as much memory as your computer will take and you can afford. If you start changing stuff, you will have heat issues (which may be how you got to this place to start with.)
Your best bet is to work from the existing processor model number, since manufacturers can change the motherboard in a given model of computer from one range of serial numbers to the next. They sometimes also offer the same model of computer with different processors and motherboards at different prices. So you can not tell much from the model number of the computer.
May I also advise you that changing a processor requires a little special procedures, equipment, and knowledge these days. It is not just unplug one and plug in the other any more. If you do not know what you are doing you could easily "fry" the new processor from excessive heat, due to incorrect installation. So look for some help if you are not sure of the details for replacing a processor chip. It's not hard, just that some things that may not be obvious are critical.
Your CPU is tied into your motherboard. Only CPUs that are compatible with your motherboard will work. You can get your motherboard model from start>programs>system tools>system information. Once you have the model # then you can start searching for the CPU options. Good Luck.
