Question about Smith Corona Typewriter SD650 Refurbished with New Machine Warranty SCM SD 650
I have used Code key by mistake and cannot correct.
It's not typing key I hit
Dick O Reilly
  • Smith Corona Master
  • 3,594 Answers
Remove the print wheel, look for bent spokes and be sure that the ribbon or correction tape are not tangled in it.
DickyO
Posted on Mar 01, 2015
What is Online Sentence Correction?
The Sentence Correction helps you write better English and efficiently corrects texts. Based on the context of complete sentences, Ginger Grammar Checker uses patent-pending technology to correct grammar mistakes, spelling mistakes and misused words, with unmatched accuracy. Ginger's grammar check software improves your text just like a human reviewer would. Enjoy the most expansive online Sentence Correction on the market. Benefit from single click proofreading wherever you type so that you improve your English writing while you learn from your Sentence mistakes.
Sentence Correction
Feb 11, 2016 | Computers & Internet
Change keyboard mode. Not typing correct letters
Hold down the "code" key, the one to the left of the spacebar that says "CODE" on it, and hit the "L" key (the one that says (Lang) on it. Should be back to normal.
Sep 21, 2015 | Lexmark Wheelwriter 3500 Typewriter
What do I do when my typewriter types different letters and symbols than the keys being hit
Turn the machine off then on or hold down the "code" key and hit Q "reset" key to get the machine to type the correct keys. This usually happens because something interferes with the free rotation of the printwheel. Check to be sure the ribbon and corredtion tape are installed correctly and check to be sure none of the "fingers" on the printwheel are bent outward. If a finger is bent, bend it back. If everything looks okay, the board or power supply is going bad.
Feb 23, 2015 | Brother GX-6750 Typewriter
I have a brother GX6750 typewriter do not understand how to install correction ribbon
well, the correction ribbon is for erasing mistakes, it literally, pulls the ink off the paper, but you have to hit the correction button, the type writer will back up and pull the ink, but you would hear ait and be able to tell the diff. I think maybe you should check 1st that the ink ribbon is the 1 closest to you, and the correction ribbon is behind the ink ribbon- also make sure they are in the correct direction- ink side of the ribbon facing your paper- sticky side of the correction ribbon facing the paper- so its you, the ink ribbon and then the correction ribbon then the paper
Feb 07, 2012 | Brother GX-6750 Typewriter
When i type a sentence and make a mistake and want to add a new word into my sentence the space bar and any keys i touch type over my existing print. how do i correct this.
You need to toggle your overwrite/insert setting.
All you have to do is hit the "Insert" button on your keyboard. Hitting it once will set your type settings so that new text will be inserted instead of overwriting existing text. Hitting it again will toggle it back.
Mar 28, 2011 | Logitech 967437-0403 Keyboard
Smith corona SL480 instruction manual. I just need a manual so I know how to use the features built into the typewriter
How to Use a Smith Corona Typewriter A Smith Corona typewriter can be either a manual or electric model. Whichever model you have, the typewriter works in basically the same way. If you are familiar with a computer keyboard, you can type on a typewriter as the keys are laid out exactly the same. Unlike a computer, typing mistakes are harder to correct and, unless you use carbon paper, you will only have one copy of any document you type.
Aug 03, 2010 | Smith Corona Office Equipment & Supplies
Every time I hit the space bar, it types a character,
Check to see if the printwheel is in correctly.
Mar 02, 2009 | Office Equipment & Supplies
Keyboad problem
Well, this happens alot, it is usualy because you are not hitting the right buttons, the keyboard is small and anyone can make that mistake. Sometimes when you pres T you might acidently hit Y. So, just be more careful when typing.
Dec 21, 2008 | Apple iPod touch
How do i turn off the delayed type on a ibm wheelwriter6
at the very top right of your keyboard there is a "print mode" key
press this key until the note in the left lower coner of the display says "char print"
however in delay print you can correct mistakes before you print - saves on correction tape
Nov 17, 2008 | IBM Wheelwriter 30 Typewriter
Smith Corona Typewriter SD650 Refurbished with New Machine Warranty SCM SD 650 Logo
66 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
James Keysor
Level 1 Expert
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
