Hello Sony RM-AV3100 remote has no codes to setup with any Integra devices. You have to try its code search method. Sometimes you may find a code. But not sure. Go to the user manaul of that remote. There is proceedings for code search process. The codes are four digits indeed. OK.
You have to make sure that you have activated zone2 in setup? It is defaulted as 7.1 Activating zone2 makes it 5.1 + 2 (make sense) Also zone2 only outputs audio hooked up thru the analog connections
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
