Question about Miele Olympus S2120 Canister Vacuum Cleaner with FiberteQ SBD350-3 Rug and Floor Tool
How can I extend the hose so I don't have to bend so far down when I vacuum. I am tall
yogi89
    New Friend:
  • 16 Answers
Check the size of the hose and see if any shop vac attachments will fit. They have the rigid wands that would enable you to stand up. If they don't fick check with some plastic pipe at lowes, home depot, etc to see if you could use as an extension. You could cut the pipe to the exact length you need.
Posted on Feb 25, 2015
Vernon Taylor
  • Miele Master
  • 6,993 Answers
You could try wearing the cleaner like a backpack...
I live in a small town and there are at least two businesses here where I could buy vacuum cleaner hose by the metre.
I have also seen purpose-made 1 metre hose extensions.
It isn't always easy but I have repaired and replaced hoses, changed ends and generally managed to use surplus and discarded hoses rather than buy new.
I suggest you approach the sort of business that supplies vacuum cleaners and washers and suchlike to other businesses rather than a high street type shop.
Vacuum starts and stops when the hose assembly is moved.
Hello, it sounds like you make have a wire loose in your canister. The canister needs to be repair by a qualified repair person due to shock hardzards.
Oct 27, 2015 | Kenmore Canister Vacuum Cleaner,...
The power head on my ocean blue vacuum will not work
Broken wire in hose, connecting power head to the vacuum?
Aug 26, 2012 | Ocean Blue Water Products Vacuum With Air...
Hoover windtunnel air - stopped working
I just has the same problem, there is a clog in the intake hose. I removed the hose and used a cloth dryer lint brush to push out the clog.
Aug 05, 2012 | Hoover UH70400 - Windtunnel UH70400...
Machine doesnt turn on. Is there a reset
Check the screen to make sure the plastic piece is depressing the switch at the bottom...the machine will not activate to on if this switch is not on..and depressed by the plastic piece on the Flair SCREEN.
Apr 29, 2012 | Ecoquest Flair Air Purifier
My Fan is somehow loose and gets jammed. I don't see how the fan metal bracket fastens to anything and therefore is sort of floating loose and the blade keeps rubbing up against the plastic...
Fan should not be rubbing up against anything. I don't think the fan is secured properly to the motor shaft. Tighten down the metal clip that holds the fan onto the shaft. Make sure it's not back too far.
Jul 14, 2011 | Ecoquest Breeze AT Living Air Purifier
Gentlemen: The LCD display on top of the purifier indicated that the filters were dirty. We removed the 2 filters, vacuumed both sides and reinserted them. We are still getting an indication that the...
According to what I found, if the filter is not reinstalled just right, it won't trigger the filter being back inplace switch.Also, try unplugging the unit for 30 minutes and then plug it back in. That may reset the switch. If tall else fails, call Honeywell Customer Service at 877- 841-2840.
Hope this helps to solve the problem, JR.
Mar 07, 2011 | Honeywell HHT-145 Air Purifier
RED LIGHTS COME ON AFTER I CLEANED THE GRIDS
hi.....
u wud have to take a pair of needle-nose pliers and rip out the metal blade at the bottom where the spark is occurring and fold it back against itself so that it is no longer "seated" into the bottom of the unit where the sparking is occurring
take care to bend the parts back in line with the blade so that lined up and could be removed and replaced into the unit without scraping anything. When u put it back in, there ll be one last "spark" or probably a couple...... and after that i shud work just fine......
thank youhave a nice day good luck
Jun 02, 2009 | Sharper Image Hybrid GP (SI724) Air...
Miele Olympus S2120 Canister Vacuum Cleaner with FiberteQ SBD350-3 Rug and Floor Tool Logo
98 people viewed this question
Top Miele Air Purifiers Experts
ray gallant
Tom Chichester
Are you a Miele Air Purifier Expert? Answer questions, earn points and help others
