Question about HP Office Equipment & Supplies
How do I set up speed dialing on my HP Officejet 5740
  • SupportTechnically
    SupportTechnically Aug 02, 2017
    Printer Support | Printer help, online printer support
    Online Printer Technical Support Phone Number 18008915603 for printer setup & services to Install Brother, Dell, HP, Epson, Canon, lexmark customer care support.
    click to know morehttp://www.printersupporthelpdesk.com/
Points To Ponder
    Master:
  • 149 Answers
While "Speed Dialing" or "Speed Dial" is listed in its fax specifications on some sites, it appears to be a mislabeled categorization of its group fax feature as HP's manual makes no other mention of it--save to say, the "fax to multiple numbers" (or multiple recipients) feature. There does not appear to be a speed dial list, but there is a phone book feature for adding contacts (individual numbers) & groups. (The following is detailed in a more explanatory way on pages 65-66 of the user's manual (http://support.hp.com/us-en/product/HP-Officejet-5740-e-All-in-One-Printer-series/6617253/model/6617254/manuals?cc=us&lang=en).
1. From the printer control display, touch Fax.
2. Touch Send Now.
3. Touch the telephone symbol to access its phone book feature.
4. Touch the person symbol for a phone book contact; or touch the multiple person symbol for a group of phone book contacts.
(Note: Contacts should be established before any of these could be added to any group.)
5. Touch + (plus sign) to add a contact/group; or touch the gear symbol (edit) to edit/delete a contact/group.
6. Touch Name.
7. Changes to contacts/groups:
•Adding a contact/group: type the name, & then touch Done.
••Adding a fax number to a contact: Touch Fax Number, enter this contact's fax number, & touch "Create".
••Adding a contact to a group: Touch Number of Members, select all of the contacts to add to this group from this printer's phone book, & touch Select followed by touching "Create".
•Editing: Select the contact/group name, & then touch Done. Then...
••Editing a Contact: touch Fax Number, enter the fax number, & touch Done.
••Editing a Group: touch Number of Members & deselect the contacts to remove from this group or touch + (plus sign) to add contacts to this group. Then touch Done.
•Deleting a contact/group: Select the name, & then touch Delete followed by touching Yes.
Posted on Feb 25, 2015
1 Related Answer
How can i Troubleshooting Fax Issues on my hp officejet 4650?
If you get issues like Faxes can be sent but not received, Faxes can be received but not sent error on your Printer then follow the given troubleshooting steps.
Solution to Faxes can be sent but not received
    ·Initially, you have to check any of the telephone line services are enabled. There are,
    1.Voice Mail
    2.Call Waiting
    3.Billing Tone
    4.Privacy Block
    5.Security Screen
    6.Anonymous Call Rejection
    7.Privacy Manager
    ·These may block your incoming faxes. So disable the above features.
    ·If you are using Automatic fax reception option on your fax recipient, then check whether the Automatic Answering feature is enabled or not, if it enables means Auto Answer green LED should be on.
    ·Check the Ring to Answer value.
    ·If the value set as answering machine that causes the issue on fax reception. Then change the value to Fax or FaxTel
    ·Now, you can receive the incoming faxes.
    Solution to Faxes can be received but not sent
      ·Check whether the dialed number is correct or not. Every one of the digits required to make a telephone call from a similar line must be dialed.
      ·On the off chance that the Speed Dial has been used for dialing or the fax has been sent from your PC, print the page to be faxed and dial the number physically on the HP Fax front board.
      ·Check whether the Tone Dialing is set on you HP Fax product.
      ·In the event that faxes are sent effectively from the HP Fax front board, but, it's fail when sent from the PC, test the communication between the HP Officejet 4650 printer and your PC by tapping the Status button in the HP Director application, or attempting to print some record.
      ·If the printing fails to send the fax, then check whether all cables (from system to HP Officejet 4650 Printer) are connected properly, if it's not then connect it properly.
      ·Now restart it. On the off chance that communication still can't be set up, Call Printer customer service team via Toll-Free: +1-800-836-3987 to resolve your HP Officejet 4650 fax issues.
Jun 27, 2017 | HP Office Equipment & Supplies
5740 hp officejet printer streaks on scan or copy
The glass is smudged or dirty or the scanner bar may have dirt on it. Cheaper to just replace the machine.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Aug 19, 2016 | HP DeskJet 5740 InkJet Photo Printer
How do I increase the font on my hp officejet all-in-one 5740 printer.
Hi again Keith,
As I already said the printer isn't where you do this, it is done in the program you are printing from.
May 20, 2015 | HP Officejet 5740 Wireless e-All-in-One...
Which free app to download,Iam trying to print with a labtop and a phone,can not print.
Hi Douglas, I am using "HP ePrint" with my HP OfficeJet 8500A via home Wifi and it works like a charm... I'm using Android on Samsung Galaxy. Hope this helps.
Nov 15, 2014 | HP Officejet 5740 Network-Ready Wireless...
Is there software to support the speed dial settings for the fax machine in my HP 6110?
Here is the link to your machine manual
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=79477&lc=en&cc=us&dlc=en&lang=en&cc=us
On page 32 or 36 of the 1st list pdf manual there is information on how to configure speed dialing
Hope it helps.
Sep 04, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How do you set up the speed dial on this model 5610 all in one?
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab27
Jul 08, 2009 | HP Officejet 5610 All-In-One InkJet...
How do I set speed dial numbers?
Here is the procedure to setup speed dials (both individual and group) on your printer.
thx
Oct 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Office jet all in one printer 4215
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
fax using monitor dialing
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 07, 2008 | HP Officejet 4215v All-in-One Printer
273 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
