SOURCE: Optical Wireless mouse does not connect
uninstall blue tooth software and start over from scratch.
SOURCE: Logitech Wireless Keyboard not resetting evidently after installing new batts.
First make sure the batteries are put in with correct polarity. Although obvious, its surprising how many people make this mistake. (Happened to me too once :)
I am not sure what model you have, so please try the following:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=7652
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=3818
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!
rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
SOURCE: Logitech S510 mouse will not turn on
I am assuming since you need batteries that the mouse is cordless. If so you normaly have to sync the mouse with the receiver.If the keyborad and mouse came as a package it will only have one receiver.There should be corresponding sync buttons for these devices.
SOURCE: Logitech Wireless CE 0682 Keyboard won't work but mouse does
did this come with software
and you might need to do a uninstall reinstall
if it worked on same pc before it should work now.
if you have a reset button on transmitter try resetting it.
SOURCE: Logitech mouse n keyboard wont connect
whenever you chage the battery you have to syncnonize your keyboard and mouse to sensor of the reciver. you can see on the back side of the keyboard there is connect button just press it and on the recevre side also press the connect buton same setting do with mouse also.
