Question about Samsung Galaxy Tab 10.1 Wifi - Tablet - Android 3.1 honeycomb - Gt-p7510mayxab
How can I install playstore on my Tablet
I have not had access to my tablet to download anything on playstore for a week. So factory cleaned and tried to reinstall but no luck
Posted by Glenys Phillips on
spy1309
    Sergeant:
  • 333 Answers
Your tablet is more likely a chinese no name one.
You can download the Play Store standalone version from here:
APK 12 FEB 2015 Google Play Store v5 2 13 Newest version unmodded
Posted on Mar 17, 2015
Cant load facebook app on my tablet
It's either you are loading a Facebook app that isn't compatible with your tab android OS Or Download the raw standalone 'Facebook apk' file from the web and try install this Or Check out the 'Facebook lite apk' file, it works great too on tabs FYI please: Raw apk or standalone apk file simply means ...you download NOT through the playstore
Oct 01, 2017 | Tablets & eReaders
The playstore on my tablet do not want to open sins i did the software upgrade
In order for your tablet to have a working Playstore, it must be compatible with Playstore.
The reason that I? telling you this is because a lot of people buy a used tablet, with third party software in which force a Google app into the tablet.
Since there is no detail about the tablet, I can only guess.
Go to settings>app. From here search for Google Services, if there is none, then it means that you must install it for your device or update it. If there is none for your device, then it means that your device does not support Playstore.
Jun 06, 2016 | Tablets & eReaders
Can't sign in to google playstore.
Hi there joe i want you first of all to check your internet connection if it is connected please check the storage or if the playstore is restricted in your country if not try uninstalling then re installing or just try the app if you didn't install it yet or do contact thier support center i hope this answer was helpful
May 24, 2016 | Tablets & eReaders
Had to do factory reset, now unable to download apps from google playstore like youtube etc, any help?
I suggest that you troubleshoot first, instead of a hard reset. Factory reset is within settings.
If any google app won't download nor install, it's probably because your google services are not updated or is corrupted. Try the next steps before factory reset.
1. Go to settings, scroll down to app.
2. From here search for PlayStore and tap it.
3. Tap Clear Cache and Clear data.
4. Go Back.
5. Search now for Google services, this one is not under the download tab, which you can notice at the top of the screen, instead got to All and scroll down until you find it.
6. Tap Clear Cache and Clear data if available.
7. Reboot phone or tablet.
Most of the time this procedure do work, some people also opt to remove the google account and sign in after the reboot.
After the boot, open the PlayStore, accept the agreement and try to download anything from the PlayStore that is compatible with your tablet. Also, just to be sure, go to settings, security, look for Unknown Sources and enable it. This feature allow you to install any apk file that is not from the PlayStore.
Mar 07, 2015 | Tablets & eReaders
My tablet don't what to go in to my playstore what should i do?
Make sure you have a wifi connection. Playstore is on the internet so you have to be able to access the internet.
Also, if the Playstore app that came installed on the tablet is lost or needs re-installed for some reason, then you won't be able to re-install it on your tablet unless you also have gmail running on the tablet or google+ or some other app that Google can use to identify you as the tablet owner.
Feb 02, 2015 | Tablets & eReaders
Every time i touch the Facebook icon it goes back to the apps s
If realoding fails, download clean master and clean junk or memory boost.
Oct 29, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
To download whatsapp on tablet
Android: goto PlayStore
Apple: goto iTunes App Store
Search for Whatsapp Messenger
Click Install.
Oct 20, 2014 | Tablets & eReaders
Noria Tablet freezes, Can't do anything with it.
I would perform a factory reset and start again. Any apps that are paid for you can download again for free.
Aug 07, 2017 | Tablets & eReaders
Samsung Galaxy Tab 10.1 Wifi - Tablet - Android 3.1 honeycomb - Gt-p7510mayxab Logo
122 people viewed this question
Top Samsung Tablets & eReaders Experts
Eric Rotmil
Eric Rotmil
CoppellTVRepair.com
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
