Netflix Logo
A
Anonymous Posted on Feb 24, 2015
How can I connect computer to tv
I want to watch netflix on my tv (from computer)
Ty Roden
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Feb 25, 2015
Ty Roden
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1013
Points
8
Most newer TVs have a VGA connector on the back with the rest of the connectors. This is generally the easiest connector to use. You can get a VGA cable from a local computer store to connect between your computer video connection and the TV. If you have an old VGA monitor you are no longer using, you may find that the old VGA cable is removable - as they are on some monitors.
Alternatively, you can connect to an HDMI connector on your laptop / PC to the TV's HDMI connector (they should be labeled) using a standard HDMI cable if you have such a connection available. This is the preferred method if you have this connector available on both devices.
Third alternative option is if your computer (or TV) have a DVI connector. This connector can be adapted to HDMI. As an example, if your computer uses a DVI connector, and your TV has an HDMI connector on the back you could buy a DVI -> HDMI cable, or just use a HDMI cable with a HDMI -> DVI adapter on one end.
Once you have connected to the TV in one of the above methods, you then have to use the TV remote and change the 'input source' until you see your computer.
Side note: If you are using a laptop, make sure that your external connector is enabled - for Windows users, right click on the desktop and choose properties then Display. (Windows 8 users, choose screen resolution in the same location).
I can watch normal series but cant watch any movies on Netflix?
User chromecast, the best way to watch Netflix on TV.
Want to watch netflix on another tv.
Hello Friend
Follow these steps to watch Netflix on another TV
    ·Determine if your TV is a Smart TV. Smart TVs connect to your home network, and can run media streaming apps such as Netflix. Connect your Smart TV to your home network.
    ·Open your Smart TV apps.
    ·Select the Netflix app.
    ·Log in with your Netflix account.
    ·Browse using your remote.
    For more info. Visit us:
    Netflix Com Activate
Mar 08, 2018 • Netflix
What is the procedure to view NETFLIX on a second TV setIs there an additional cost? If so how much?
hi Frank.
this is what i just found on the internet.
How to watch Netflix on 2nd TV? Method 2 Smart TV
  1. Determine if your TV is a Smart TV. Smart TVs connect to your home network, and can run media streaming apps such as Netflix. ...
  2. Connect your Smart TV to your home network. ...
  3. Open your Smart TV apps. ...
  4. Select the Netflix app. ...
  5. Log in with your Netflix account. ...
  6. Browse using your remote.
6 Simple Ways to Watch Netflix on TV - wikiHow
https://www.wikihow.com/Watch-Netflix-on-TV Search for: How to watch Netflix on 2nd TV?
how to view NETFLIX on second TV Google Search
I am try to stream Netflix from my computer to my Samsung TV
How to Watch Netflix Instantly on your HDTV
www.handymanhowto.com/how-to-watch-netflix-instantly-on-your-hdtv...
I have a samsung tablet i should b able to connect the usb port into the tv from the tablet and ... Am I spinning my wheels trying to connect this PC to that TV? .... I have a windows computer, that i play Netflix on through an HDMI on our TV.
How to Watch Netflix Instantly on your HDTV - Part 2
In this example I have my Windows 7 laptop connected to a Samsung HDTV with an HDMI cable. ... Watch Netflix - Computer Displays Blank or Screen Saver on TV .... It seemed like better quality sound kept trying to break through and then go back to whatever ... I am guessing the HDMI cable will give much better quality.
2answers
Can I connect directly to Netflix using this TV?
Netflix Phone Number
Phone Number
888-638-3549
Press 0 at each prompt.
or they call you instead
http://gethuman.com/call-back/Netflix/
Average Wait: 5 mins - 24 hours, 7 days
Phone Number
888-638-3549
Mar 29, 2015 • Netflix
4answers
What special equipment do I need to watch Netflix
All you need is a computer and a connection to the internet and you can watch it directly on Netflix.com. In addition you can download the free Netflix app onto your smart TV, game console, streaming player, phone or tablet.
If what you are really asking is how do you watch it on your digital TV (not smart TV) then you will need a wireless home network and a streaming internet player such as Amazon Stick, Roku or Chromecast. Your digital TV will need an HDMI input connection. Most players are also powered through a USB port so it would be helpful to have a USB port on the TV but it can be powered with a transformer at a normal AC plugin.
Mar 10, 2015 • Netflix
3answers
Can I get Netflix on my TV if I don't have any cable or satellite service?
Netflix is an online streaming service....this means as long as you have the internet and a smart box or tv or computer laptop or tablet you can use it to watch netflix amazon hulu etc.
it is better to use a cable (Ethernet ) from router to tv as opposed to wifi.without internet no netflix.
Feb 28, 2015 • Netflix
2answers
How do I watch netflix on tv as I have signed up for netflix on line
Your tv needs to have a connection to the internet. If the tv does not have it, you can use a peripheral like a game system that has internet access. A lot of newer tv's have internet access with direct links to Netflix and other online viewing providers. You can also hook up a computer to your tv with a cable and mirror or extend the display to the tv. Then connect to Netflix through your computer.
Dec 24, 2014 • Netflix
2answers
Do you have to have cable tv to have netflix?
No, you do not have to have Cable TV in order to get the Netflix service. However, in order to watch Netflix you basically need to have an internet connection preferable of decent speed. You will also need a supported device that will let you watch Netflix.
The internet speed will ultimately determine whether you get quality video output on the device you intended to watch Netflix.
You can watch Netflix on your computer or you can use a device (generally now called a media device) that will allow for you to watch Netflix on your TV.
The Netflix app comes on many different media devices, which you essentially plug to you TV and connect to your home Internet connection.
Newer TV have the Netflix app built in to them as well as Internet. These TVs are referred to as Smart TV.
Right of the top of my head are the following Netflix capable devices Xbox 360, Roku, Wii...
Here are a list of other supported devices on Netflix's Website:
Top Netflix Computers & Internet Experts
vince
NOEL
NOEL
Are you a Netflix Computer and Internet Expert? Answer questions, earn points and help others
