Question about Philips 27PT6441 27" TV
4 digit access code put in by previous owner. blocks some channels
Cannot find previous owner to get code. is there some way to override code?
Posted by Terry Kirkwood on
Anonymous
Use 0711 Hope that works. If you need more details I could email a portion of the service manual covering that procedure.
Posted on Nov 13, 2007
Reset for a parental block.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 24, 2015 | Olevia Televison & Video
Unlock the code for lg tv
Dec 05, 2014 | LG Televison & Video
I have an apex tv dvd combo. the parental controls are blocking the dvd from playing how do I unblock it?
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
  1. To use the override code:
  2. Hit the MENU key to get to the menus.
  3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
Jun 01, 2012 | Apex Digital Televison & Video
I bought a used TV with an existing access code. I don't know the code and some channels are blocked. How do I disable the code? or reset it?
Hello
First disabel the lock and re-enter your own lock code. For this do the following.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Jan 10, 2011 | Philips Magnavox TS3260C 32" TV
El tv dice blocked by autolock channel blocking access code
Hello
Your TV is locked I thinks.
Read this well before you proceed
although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code , and enter a second time it it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, goto BLOCK, and push the "right arrow" key. Go to Blocking Options and press "right arrow" key. Goto master disable and press the right arrow key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Dec 04, 2010 | Philips Magnavox 27MS343S 27" TV
I have gotten and hdtv from a friend and when I turn tv on it says I need a pin number to enter. I can not get a hold of them to get pin. Is there anyway I can override this in the settings program?
The Factory code number is 0 0 0 0 If the code has been changed, You can select to reset it using the Setup Code either under the channel blocking or setup code section.
Once there, Press 0 7 1 1
You will be given a message "INCORRECT ACCESS CODE" Press 0 7 1 1 on the remote again
Next, "enter your new access code" shows on screen.
Now you can enter a new 4 digit code. (write it down somewhere)
Dec 03, 2010 | Philips Televison & Video
I was given a mitsubishi tv but the previous owner had a password lock on it. Is there any way to access the tv by rebooting or something in order to use the tv?
1. Press the Mode button until the LOCK CODE display appears.
2. Enter the 4-digit code using the CHANNEL SELECTOR buttons.
3. Press the CANCEL button to cancel the previously locked channel. The LOCK CODE number display flashes.
4. To exit the CHANNEL LOCK mode, press the MODE button until only the Time and Channel display appear.
Secret text if the code is forgotten!
2. Press Channel Number "9" and "QV" simultaneously. Knowledge of this procedure defeats the channel lock system.
Nov 12, 2009 | Televison & Video
I have a konka television from a previous owner with the channels blocked. is there an override code to unlock the channels 0000 does not work. i really wanna be able to watch my tv as soon as possible
Codes is almost impossible to break,tries reset everythings in the menu setting,unplug for couple hours,just see if it reset itself,that all could do more than three years old tv not possible find reset codes.
Oct 10, 2009 | Konka DT138U 13 in. TV/DVD Combo
Smartlock code
I used the following that I found on a site that compiles v-chip reset solutions:
Philips and Magnavox:
Apr 03, 2008 | Televison & Video
GE: 13" Model13GP341 vchip parental control locked
magnavoxes and phillips tv's uses overide codes .those of you who have either of the two tv sets try this code 0711 hope it works.
Nov 05, 2007 | Philips Magnavox 27MS343S 27" TV
Philips 27PT6441 27" TV Logo
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
