Here is the link I found for Cosmo communications site.
Hope it helps.
Chadman
Read the manual that came with the remote. Most of the time you can find your device when you put the remote in a "search" mode and then you have to press a button several times, till the TV switches off. Then press anything again and your remote should be set up. Something like that should be on the remote for setup. When the TV responds, check all buttons, to see if any of the keys switches the AV.
SOURCE: My tv has been block.
sounds like U have put the aprental lock on U will have to figure out how to take it off with the remote or at the panel buttons
SOURCE: durabrand tv model Bh1304D stuck on av
CALL 1-877-337-3639 AND THEY W/TELL YOU TO BAD :-( THAN THEY WILL TELL YOU TO ORDER A REMOTE FROM 1-800-313-8495 OR 1-800-668-1067
SOURCE: tevion television
tevion uses the same codes as "Konka".. if your universal remote has codes for konka, then it should work.
SOURCE: how can i put it on AV mode?
you will have to call the number on the back of the TV. There you can by a remote. I had the same problem.
SOURCE: My Sanyo TV remote AV button has failed. Is
Why would I tell you how I fixed my problem if I have to pay you to tell me.
