Question about AOpen Computers & Internet
My computer has no beep at all, am using an Aopen MX46-533V board
Posted by anthony laidlow on
Carlos Krue
    Scholar:
  • 175 Answers
I am assuming that you are replacing or installing a new mobo. You need to read the manual to see if it has an option for speakers, most do. You need to look the details for the "front panel" where you connect wires for power, hard disk lights etc.
Posted on Feb 24, 2015
1 Related Answer
Anonymous
  • 23 Answers
SOURCE: aopen ax34 mb - the computer was working-now 1 beep then Crashes
You're right. Your board is shot. Replace it.
Posted on Jul 10, 2009
I have an AOpen vKM400Am-S Motherboard, when i turn it on a red light and cpu fan turns on but no video to my monitor,i checked if my video card works on a difrent pc and it did, my pc wont turn on
this caused by RAM error, open your computer, disconnect ram, turn on your computer?is computer beeping, 1 long and 2 short beep??if yes the problem is come from your ram, clean your ram connection then connect ram to mother board, turn on your computer, is the video come to screen??if no, try to connect another ram to your computer, for sure use new ram
i hope this helpful
thank you for using fixya
Feb 05, 2011 | AOpen MX4LR (91.89Y10.002) Motherboard
Where to find the part number for the Dr. LED option?
with the indulgence of ginko....
May 25, 2008 | AOpen AX4B-533 Motherboard
My computer starts with a long beep and nothing else happen but a red light led (STBY_LED). I've got a Aopen computer motherboard. please help
Long beep means Problem with System Memory. Open the CPU cabinet and Locate the RAM. Remove the RAM by sliding Down both Clips. and insert the RAM back. it will fix the problem. If problem still persists. Try replacing the RAM module. best of luck
Feb 01, 2011 | AOpen AK86-L (918AD10201) Motherboard
Computer beeps but doesn't start.
The beeps are an error code. Most times they are signifying a RAM or video card problem. With your explanation I would check the video card first. The card might have overheated or just plain crapped out on you. Try replacing and rebooting. Hopefully this will have fixed your problem. Sorry. Hope this points you in the right direction & Good luck.
Jun 03, 2009 | Intel AOpen XC Cube EZ65 P4 Media PC...
No boot,long beep over and over,no lcd's and no moniter
you reset the board by removing battery for a few seconds.
Dec 18, 2008 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Is it dead or can i bring it back to life
http://download.aopen.com.tw/...ALL INFO MANUALS AND DRIVERS FOR YOUR BOARD CAN BE FOUND HERE.RICHARDM69
Dec 09, 2008 | AOpen s661FXm-7S Motherboard
Motherboard
TAKE YOUR DDR CARDS OUT ,, AND SWITCH THEM,, ,,IF THAT DOESNT WORK TRY WITH ONE AT A TIME,, GOOD LUCK
Oct 05, 2008 | AOpen MX46-533V (91.89U10.061) Motherboard
Aopen ax34 tamper alarm--how to reset????
I don't think that board actually has a tamper alarm in the bios, password security yes but I saw no mention of a tamper alarm. Besides, a tamper alarm won't stop the pc from booting, it just lets you know that the case has been opened....sorry. I think you likely have a mainboard/ram issue.
First thing is to clear the bios. Here's how. Right beside the floppy connector, there is a jumper labeled 'JP14'. Please do the following
  1. Turn off the pc and remove the ac power cord.
  2. Remove the atx power connector from the mainboard (from power supply).
  3. Locate jp14 and move the jumper from pins 1 and 2 to pins 2 and 3. Wait 10 seconds.
  4. Put jp14 back to pins 1 and 2
  5. Reconnect the atx power connector.
Or you can just unplug it from the waal and remove the bios battery for an hour.
sa code
Try to fire it up again. If it still won't boot, then let me know the number of beeps it makes and the pattern to the beeps ie: one long beep then another long beep or 1 long beep then 2 short ones. These beep are actually telling you what the problem is.
Hope this helps! Post a comment and let me know how you make out.
Aug 24, 2008 | AOpen AX34-U Motherboard
Computer will not boot
3 beeps = memory
long beeps = processor
long and short mixed = main board,,,
yours sound like memory, try the memory in another pc and see if it works
if it does its your processor
cheers
Jan 05, 2008 | AOpen AX34-U Motherboard
Computers & Internet Logo
Top AOpen Computers & Internet Experts
Michael Thomas
Michael Thomas
Joe Goldman
Joe Goldman
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
