Question about Saeco Classico Espresso Machine
Poor coffee after cleaning
Hi. I just cleaned my Saeco Classico last night, and today the espresso is terrible! There is almost no crema and the coffee tastes watered down. I"m worried I damaged something while cleaning it. The coffee takes about the same time to come out as it used to, it just tastes bad and has no crema.
I did two things that are unusual:
First I took apart the portafilter. There are three screws holding it together andI removed them to reveal a rather delicate mechanism with springs and a nozzle, etc. I tried to be careful to put this back as it was, but I'm worried I might have screwed it up somehow.
Second, when cleaning the screen I couldn't get some coffee out of the holes, so I carefully tried to scrape them out with a pin. I read later that you should not use sharp instruments, so I'm worried I might have enlarged one or more of the screen holes, possilbly affecting the pressure of the steam.
Anything else I might have done wrong?
Posted by denverdash on
  • 1 more comment
  • denverdash Nov 13, 2007
    Thanks for the quick reply.
    Well, I used the pin pretty delicately. If there was a film, I doubt I scratched much of it. We've made several cups of espresso now and they are all the same. I didn't use any chemicals--just warm soap and water.
    Also why would that effect the crema? The visual quality of the shots is 100% different. It's like the difference between a shot of espresso and a cup of coffee.
    Any other thoughts?
    Any other thoughts?
Anonymous
    Sergeant:
  • 279 Answers
The portafilter on this model is pressurized, and you're not really supposed to take it apart. Considering that it's not just taste, but consistency that is wrong, I'd say it's almost certainly the portafilter that's the problem. Most likely it wasn't assembled properly, and isn't pressurized like it should be. I checked with Saeco support, and was told that even their techs have a hard time reassembling these properly - and they have the proper, specialized tools to do the job.
You're going to need to replace the pressurized portafilter.
And I have more good news - Saeco currently is out of stock on them. They have a purchase order out for more from their factory, however they said it could be up to a month before they have them in stock.
You can check their current stock here for black:
http://www.saecooutlet.com/index.asp?PageAction=VIEWPROD&ProdID=181
or here for grey:
http://www.saecooutlet.com/index.asp?PageAction=VIEWPROD&ProdID=180
You can also contact them at 1-800-933-7876 and ask if they have an updated ETA for when more will be in. Or email them at [email protected]
The pressurized portafilter is $50.99 currently.
-Dyllan
Posted on Nov 14, 2007
Anonymous
    Novelist:
    Champion:
  • 244 Answers
Is it the first time you do cleaning? It is possible you screwed it inappropriate please contact the repair shop because there are really having an experties to do that job.
Best regards,
Philip
Posted on Nov 13, 2007
Anonymous
    Sergeant:
    Champion:
  • 306 Answers
If the screen had a film covering to keep it from rusting and you scatched the film off thats what your tasting....dont swallow it.
if you used and cemicals to clean it that arnt recommended your probably going to have to replace it.
  • Anonymous Nov 13, 2007
    Most likely there was something damaged durring the last cleaning. My advice it to have hands on professional repairs.
I have turned the grind knob all the way down, below 1.
Sounds like there is not enough coffee to make a solid puck. If you get crema, grind coarseness sounds ok. A finer grind will produce less coffee grounds for the puck and increases chance of clogging.
You may have to balance grind size with amount of crema to get solid puck.
Big problem with these is you want dark roast for espresso, but oil on beans clogs grinder. Are you using a dark roast? A medium roast works better in these. Or, can you increase the grind time? My Super-auto had a program option to increase time. But not in reg instructions. Got it from authorized repair facility.
May 04, 2016 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Classico has problem. The pump is working
It sound as though the boiler is blocked by scale. May also be the coffee filter that's blocked. I am not familiar with this machine, but assuming that it's just a manual espresso machine, try running it with the filter handle removed. Any water emerging? If so, the coffee filter cup and/or filter handle outlets may be blocked. If there is only a small flow the boiler is almost certainly blocked with scale and descaling may cure the problem (do the first run with the filter handle off the machine. Next run with it on)
Oct 22, 2013 | Saeco Classico Espresso Machine
Water does not heat
More then likely it's the boiler.
Apr 26, 2010 | Saeco Classico Espresso Machine
No Crema
Hi
If your talking about the tube on the brew unit, you are probably missing the spring or if you have the spring its upside down. Again if this is what you are taking about is the check ball at the bottom of the spring(ball in first, small end of the spring on the ball, O-ring, then the manifold)These things are important for creama.
Nov 08, 2009 | Saeco Magic De Luxe Espresso Machine
Hot water come out from steam wand when pumping Saeco Classico
Gasket on steam valve is worn. Replace gasket and or steam valve.
Mar 05, 2009 | Saeco Classico Espresso Machine
Steam still coming through brew group even when pump not ON
I posted response and solution to similar issue see post below and comments :
YOU NEED TO LET MACHINE COOL OFF AFTER YOU TURN IT OFF OUCH!!
You can release pressure placing a cup under steam wand open slowly and partially while machine is OFF and let hiss out slowly. Then open cup slowly if you have to force it open DON'T. That PUCK sound can make you afraid of your machine can't it. I wont admit I haven't done that four or five times.
posted by bronwenmair on Jul 08, 2008 Report abuse
We have a Saeco Classico that worked very well when we first got the machine. Now the coffee is bitter and there is no crema in the shot at all. We tried changing grinds and tamping, nothing seems to work. Can you help? Thanks so much. We miss our morning coffee :-)
Jan 20, 2009 | Saeco Classico Espresso Machine
No crema
Sounds like the handle where you put the coffee in needs replacement, if you leave the machine on for long periods with the handle on there is a metal spring inside with plastic parts that regulate the pressure in the tamping basket. 9 BAR is the desired pressure to produce crema. the plastic parts can melt and the spring looses tension. If you place the handle on, lock it, the it should shift slightly backwards on its own if you have to help it I have bad news replacement time. I have seen replacement from 25.00 - 90.00. I have two classicos and already replaced one handle and have to do the next. It could take one time of leaving the machine on all day. Good to get in habbit of turning off the machine immediately after use let it cool slowly attached to unit and clean it when you get home. Immediate cleaining in cold water could make the spring fatigue faster and also cause this problem.
If you are brave and can remember where parts were; take the three screws off where the coffee comes from handle slowly separate the parts and you will see if plastic melted, is distorted or spring is like mush.
Here is the saeco parts diagram and parts ordering site but I warn you its the most expensive
www.saecoparts.com/SaecoEspressoClassicoBodyparts.html - 70k -
Jul 08, 2008 | Saeco Classico Espresso Machine
Prime it
1. Open the steam knob all the way.
2. Turn on the pump (coffee Button)
3. Turn on the power to the machine.
The machine will start to pump hot water out from the steam wand. When you get a steady flow, your machine has been primed.
For Descaler, Cleaners and Parts for your saeco machine visit
www.CeriniCoffee.com
May 28, 2008 | Saeco Classico Espresso Machine
Burned taste
Descaling often removes bad tastes and smells.
To order descaler or Saeco parts for your espresso machine please visit www.cerinicoffee.com
Dec 12, 2007 | Saeco Classico Espresso Machine
How can I adjust my boiler ? the water is only at 140 degres
The thermostat may have gone bad on your espresso machine.
Saeco parts and cleaning supplies:
Apr 19, 2007 | Saeco Classico Espresso Machine
Saeco Classico Espresso Machine Logo
117 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Ekse
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
