I can only especulate on all the possible reasons, so let go one by one throuh them and their possible solutions:
1. The RX3000 Ipaq family has a known mechanical issue on the switch that senses when the back cover lid is properly closed.
When the switch is nor properly depressed, the PDA won't charge the battery if plugged on the cradle or to the USB sync cable, or won't turn on.
Remove the back cover lid and the battery, put them back again. Check the cover lid is placed flush and that there is not any gap between the cover and the PDA body.
Try again in power it on and/or charge the battery, confirming the orange LED light is turning on.
2. False contact on such back switch.
You need to find exactly where is located the switch that senses the battery cover lid.
It's located at the right/bottom side thru the battery bay. Check that there is not dirty or dust accumulated, causing that is sticky such area, which prevents such switch to work properly.
If you find nothing obvious, you can use small pieces of transparent tape (or masking tape) and put them on the internal side of the cover lid that is in contact with the switch (you have to locate first such area), put the battery and coverd lid again, and try to power it on. You can add a 2nd or 3rd layer of tape to depress such switch.
3. Broken cover lid. Check that is not broken in any part or corne rof it. If it's so, then replace it.
4. Defective switch.
Unfortunately is necessary to open the PDA and check with a continuity (or ohm meter) the performance of such swicth, which is easy but usually a technician does it.
You have the option of send it to be repaired, or try it yourself, which will require to buy a switch part, or pulled it from a PDA with possible working switch or the whole mainboard (or the mainboard alone) and swap the parts. It requires a minimum of technical skills to do it.
Best regards,
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
- Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
- Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
- Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.Figure : Charging with the universal desktop cradle
- AC adapter into electrical outlet
- AC adapter into universal desktop cradle
- HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
- Connect the HP iPAQ Pocket PC to an A/C power supply.
- Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
- Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
- Turn on the HP iPAQ Pocket PC.
