Question about RCA F32450 32" TV
I've got a old 32" RCA TV. I turn it on, and the power light comes on then shortly after that the TV comes on. After about 3 seconds the TV turns off, why is this happening, and what can I do to repair this problem. The TV is 10 year old.
Posted by CLARENCE CONEY on
"32" rca tv about 3 years old was on & it went black- power light is on"
sounds like the sceen is dead, if you are receiving nothing on screen, then it sounds like either a component and/or screen is gone... however, check the tv input to make sure it wasnt acidentally switched to an input channel with nothing selected... if that does not work, call local tv repair or mfg customer service tech. if under warranty, have repaired or replaced. without physically seeing tv, it is hard to diagnose issue outside of information given. could be simple board replacement or could be screen.. but check input first, if a dvd player plays, then it could be just component or input on wrong selection
Oct 17, 2010 | RCA 32V550T 32" TV
Turns off when u turn it on
You probably have a bad flyback transformer. This is a common problem for this set. A 32" is worth a check out fee.
Oct 13, 2009 | RCA F32650 32" TV
Rca l32wd22 blackscreen
princess_dc6,
Just recently, I was told how to get another tv.
You find a good TV service centre and ask them to fix it. If they cant you take the work order from your tv sc and call 1-877-297-8391.
You will get yourself a tv
Jun 01, 2009 | RCA L32HD31 32 in. LCD HDTV
No listing of 3 digit codes for Sony Trinitron, RCA universal rem
  1. Turn TV on.
  2. Press and hold TV button and Power button until light stays on.
  3. Release both buttons.
  4. Aim remote at TV and press the power button every 5 seconds until TV turns off.
  5. Press stop button at bottom of remote.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Mar 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
[email protected]
Jul 18, 2008 | RCA HD52W58 52" TV
TV will not come on
How old is this TV?
Sounds like it has high voltage failure.
(If you hold your hand on the screen when you try and turn it on, do you feel the static? )
Unless the set is over 10 years old, I would overhaul the high voltage circuit. Should cost under $200 at a shop.
Jan 03, 2008 | RCA 32F531T 32" TV
Tv does not turn on.
There is probably a short or a near short loading the power supply circuit, a leaky capacitor, shorting diode, transistor,IC,LOPT etc. Have the set checked by a technician near you.
It is still worth repairing!
[email protected]
Dec 06, 2007 | Televison & Video
RCA Guide Plus Gold Gemstar
The set tries 3 times to come on (3 blinks) if there a problem such as a short, it will cycle without turning on. Unfortunately your set is notorious for having bad flyback transformers. Most likely the horizontal output transistor is shorted as well. Common causes for your symptom are: LL05 (horiz out transformer) RCA part# 257805; TL 02 ( horiz output transistor) 2SC5148; and open connections on the printed circuit board at LL 04 and L14401 (coils) all of which can cause the horizontal output transistor to be shorted.
0
Nov 25, 2007 | RCA F32450 32" TV
RCA 32V420T (32 inch)
I think that vertical deplection IC of you tv set is shorted. Please check also the YOKE of the unit, its maybe grounded.
Sep 10, 2007 | RCA 32V420T 32" TV
RCA F32450 32" TV Logo
60 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
