Apple iPad (16 GB) WiFi Tablet PC Logo
A
Anonymous Posted on Feb 24, 2015
How to rid blue lines on my. iPad screen?
As soon I power up my I pad getting blue perimeter lines around around paragraph and different sizes rectangles?
Willie Burks
Level 1:
  • Contributor 32 Answers
  • Posted on Feb 24, 2015
Willie Burks
Contributor
Level 1:
Answers
32
Questions
0
Helped
14325
Points
89
Try to force shut down your device then
I have a iPad Pro and my screen has changed from a full screen to one that us 1/2 full what is my problem
How to Turn Off Split Screen on iPad Split View is enabled by default on the iPad. To utilize the feature, you can drag an app from your dock to the right or left edge of your screen to open the app on a portion of the screen. If you have multiple apps open and want to close one without turning off the Split Screen or Multitasking functions in settings, you can return to a full-screen view of a single app by dragging the edge of the app you want to remove to the edge of the screen.
If, however, by "getting rid of split screen on iPad" you mean turning the feature off completely, that's something you can do in Settings. To turn off split screen on the iPad:
  • Open the Settings app on your iPad.
  • Tap General.
  • Select Multitasking & Dock.
  • Toggle off Allow Multiple Apps.
How to Get Rid of Split Screen in Safari on iPad Using split screen in Safari on iPad was a new multitasking feature for iOS 10 that continues in iOS 12. This allows you to open two separate Safari web pages simultaneously on your iPad. To start, open Safari on the iPad. You can then open a second Safari tab in split screen in one of four ways:
  • Tap and hold a link; select Open in Split View.
  • Tap Command+N on an external hardware keyboard to invoke Split View.
  • Drag a tab from its space to either the left or right side of the screen to open it in split screen.
  • Tap and hold the icon that opens your tabs view in Safari. It looks like two overlapping squares. When you tap and hold, options will pop-up. Select Open Split View.
But what if you want to get rid of split screen in Safari? What if you're done using the two tabs-how do you turn split screen on the iPad off? To close split screen in Safari on your iPad, you can do one of the following things:
  • Drag the tab(s) from one of the screens to the other. Once the last tab has been dragged to the opposite side, Safari will return to full screen, which will turn off split screen.
  • Or, you can tap and hold the tabs icon, which looks like two overlapping squares. Then select Merge All Tabs. This will merge all your Safari tabs back into a single window, which gets rid of split screen.
My iPad has a black screen with the apple on the screen. I have tried turning it off and on and it still won't come on. Can you please tell me me what I am doing wrong.
the i-pad has 2 power control buttons
one on the side that turn it on and off and the other at the bottom that you use to get different screens
sometimes you can get pas a loop situation by pressing both buttons and holding both in for about 30 seconds
it reboots the system
4answers
How to replace I pad 2 broken screen
Is the screen broken or is it just the digitiser? There are many excellent videos available which take you through the process of replacing all parts of your iPad.
However, it is not something that can be fixed easily and you need to exercise great patience in dismantling your broken iPad and replacing the damaged parts.
Make sure you have plenty of space in which to work and place all the parts of the iPad around your working area so they are easy to reach.
Good Luck.
2answers
How do i get my pad to go to home page
Can you get into the settings if so go to the general settings snd you should see reset at the bottom press this and the whole ipad should go back to factory settings . Don't worry about your folders and other stuff you have it wont delete anything hope this helps
How do I use my I-Pad when I don't remember the Password anymore?
You can connect your ipad to itunes... in recovery mode... switch off the ipad and then turn it on with holding the power button and the home button simultaneously untill you find itunes symbol on your ipad screen... then select restore in itunes... Remember it'll wipe all your personal data... but you can access your ipad again.
MY i pad will not charge
As soon as you connect your iPad to a working charger, it will beep. If you plug in the cable and you don't hear the beep, assume something is wrong. Just find out what, the cable or the charger.
Don't try to charge the iPad with a computer, because the 500 mA a USB connector from a computer can give, is not enough even to start.
But you can use a computer to test the cable, because the iPad should beep and say on the screen not charging.
If there is no beep when connecting to a computer, you have to use another cable. If it beeps, buy a new charger. 5 Volt 2 A. The best an Apple charger.
Screen display on iPad 2 changed to blue background with slight flickering. This happened while using - it did not drop. Reset has not solved problem.
Turn it over on your lap or on something soft like couch or carpet. Karate it chop it on the apple logo. Start softly and keep using more force. Folks have even used a hammer to do this but I don't advise it. You can also drop it face down on carpeted floor. Your ipad is likely stunned and needs to be stunned again to return to normal.
The icons and keyboard on ipad does not fit screen display on ipad
if this is within an app, it may be normal as iPhone apps can run in compatibility with the iPad, however certain things will be a bit distorted due to the different screen sizes/resolutions
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
