Question about Vehicle Parts & Accessories
DESciper.net maganda kapag may roong hack para maganda ang weapon ng iba ..
5 Related Answers
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: ang question ko lng kc
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Ruel Lumpas
  • 41 Answers
SOURCE: anu yong solution kapag ang built in camera ng
check mo sa system device manager kung properly installed yung driver ng cam mo. if not, load mo ulit yung cam driver. if yopu are using win7, auto configure na yan sa internet right click mo lng yung not properly installed na device then select scan drivers for auto detecting and installing drivers galing sa internet.
Posted on Jan 14, 2011
mopali
  • 13 Answers
SOURCE: hindi ko magamit ang internet
use a magical jellybean finder
Posted on Aug 01, 2011
harry tunacao
SOURCE: ano po ang email add
dear wish ko lang! ako po c harry tunacao nasa saudi po ako gusto ko sana manghingi ng tulong po sa inyo ate vicky yung tatay ko kc matanda na gusto ko sana ipa gamot kulang kasi yung pera ko!tapos yung nanay ko wala ring trabaho kulang rin ang suporta ko sa kanila.tapos yung sahod ko maliit lang d2 sa saudi.sana ate vicky matolongan u po ako! maraming salamat po!
Posted on Oct 10, 2011
SOURCE: Magandang hapon pogusto ko po sanang malaman ang
gusto ko pong maka sulat sa wish ko lang kaya lng po di ko alam kun panu mka sulat kc di ko alam ang website at mag send ..tulungan niu po ako meron lng po akong hihilingin para sa ate ko pong mi sakit na epilepsy..plls,,.tnx ako po yung kapatid nia n taga iloilo..
Posted on Sep 02, 2012
Anu po ba ang tamang gasolina ng honda tmx 155
Hi, Anonymous na mahusay na tanong, bago ko simulan ipaalam sa akin ang mga motorsiklo na may valves at upuan na dinisenyo upang tumakbo sa leaded fuel isyu, maaari kang magpatakbo ng unleaded fuel na walang isang lead additive na walang problema lamang palitan ang valves at upuan sa mga dinisenyo para sa unleaded fuel ang Susunod na kailangan mo ng isang top end overhaul. Sa sobrang bihirang mga kaso, ang ilang mas mataas na mga engine ng compression ay mag-ping gamit ang pinakamataas na oktano na graded unleaded fuel na magagamit sa mga kasong ito ang paggamit ng isang lead additive o aviation fuel. Ang Octane rating ay isang sukatan ng kakayahan ng gasolina na labanan ang 'magpatumba'. Ang pangangailangan ng oktano ng isang engine ay nag-iiba sa compression ratio, geometrical at mekanikal na pagsasaalang-alang at mga kondisyon ng operating. Ang mas mataas na numero ng oktano ay mas malaki ang paglaban ng gasolina sa katok o pinging sa panahon ng pagkasunog. Ang inirekumendang antas ng oktano para sa karamihan sa mga motorsiklo ay karaniwang oktano 87, ngunit tiyaking suriin ang manwal ng may-ari ng iyong bisikleta. Karaniwan, ang iyong motorsiklo ay hindi makikinabang mula sa paggamit ng isang oktano na mas mataas kaysa sa inirerekomenda sa manwal ng may-ari. Gayunpaman, ang ilang mga modelo ng motorsiklo ay may mga high-compression engine at elektronikong mga kontrol, na idinisenyo upang makinabang mula sa mas mataas na output ng kuryente at pinabuting fuel economy ng mataas na fuel ng oktano. Dahil ang mga pangangailangan ng oktano ay maaaring mag-iba sa mga kondisyon ng operating at kapaligiran, ang iyong bisikleta ay maaaring mangailangan ng mas mataas na fuel o oktano kaysa sa inirerekomenda upang maiwasan ang katok. Sa ilalim ng linya, gamitin ang pinakamababang grado ng oktano na nagbibigay sa iyo ng katanggap-tanggap na pagganap nang walang katok o pinging. Para sa karagdagang impormasyon tungkol sa iyong isyu at mahalagang "LIBRE" na mga pag-download na kakailanganin mo para sa pagtingin at pag-print mangyaring mag-click sa asul na mga link sa ibaba. Good luck at magkaroon ng isang kahanga-hangang araw.
Honda TMX 155 Review 2014 Review Specs Totally Motorbikes
Fuel consumption of tmx 155 thunder 125 STX 125 CT100
Honda TMX 155 2013 service manual DOWNLOAD FREE FULLMANUALS COM
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 14, 2014 | Honda Motorcycles
Tip
How to Generate More Traffic by Using Google Translate.
When writing a Tip or Trick, you can use Google Translate to write them in additional languages besides English resulting in more customer traffic from other countries.<br /><span>Al escribir un Consejo o truco, puede utilizar Google Translate para escribir en otros idiomas adem&aacute;s de Ingl&eacute;s que resulta en m&aacute;s tr&aacute;fico de clientes de otros pa&iacute;ses.</span><span><br /></span><span>Lorsque vous r&eacute;digez un Conseil ou Trick, vous pouvez utiliser Google Translate pour les &eacute;crire dans d'autres langues que l'anglais r&eacute;sultant du trafic des clients d'autres pays.</span><span><br /></span><span>Kapag sumusulat ng isang Tip o trick, maaari mong gamitin ang Google Isalin sa isulat ang mga ito sa karagdagang mga wika bukod sa Ingles nagreresulta sa mas maraming customer ang trapiko mula sa iba pang bansa.</span> 当写一个提示或技巧,您可以使用谷歌翻译写在英语之外其他语言的其他国家更多的客户流量导致他们。
on Nov 09, 2010 | Computers & Internet
Palaging drain ang battery ng xr ko at walang ilaw
Hi, Anonymous bago subukan ang anumang mga de-koryenteng sangkap sa Nagcha-charge System ito ay "IMPERATIVE" na mayroon kang isang ganap na sisingilin baterya ng 12.5 volts o higit pa at ma-ipasa ang isang wastong "LOAD" test kung kinakailangan, maaaring mayroon kang isang paunang pagbabasa ng 12.5 volts o higit pa ngunit maliit o zero amperage, ang baterya ay may mali at dapat mapalitan. Ang mga uri ng baterya ng AGM ay nahuhulog sa sitwasyong ito nang higit pa kaysa sa lead-acid na mga baterya.
1. Suriin ang mga terminal ng baterya para sa pinsala o kaagnasan, lagyan ng tsek ang mga kable ng baterya sa "BOTH" na nagtatapos para sa maluwag, nakakagambala, o sirang mga konektor, "SA ISANG" at sa labas ng cable harness, magsagawa ng pagkabit ng pag-ikot ng pagsubok at suriin ang mga cable na may isang ohmmeter kung kinakailangan.
2. Upang suriin ang regulator unplug ito mula sa stator. Sumakay ng isang pagsubok na ilaw at i-clip ito sa negatibong terminal ng baterya at pagkatapos ay pindutin ang unang isang pin at pagkatapos ay ang iba pang sa plug na napupunta sa regulator. Kung makakakuha ka ng kahit na ang pinakamaliit na halaga ng ilaw mula sa light test ang regulator ay toast. Upang gawin ito sa isang metro: itim na humantong sa baterya lupa, pulang lead sa bawat pin sa plug, magsimula sa boltahe scale mas mataas kaysa sa 12vdc at ilipat ang boltahe scale down sa mga hakbang para sa bawat pin. Anumang boltahe ay isang masamang regulator.
3. Sa kabilang bahagi ng pagkakakonekta plug ng regulator. Itakda ang multimeter para sa Ohms x1 scale at sukatin para sa paglaban sa mga pin ng stator. Dapat mong basahin ang isang bagay sa paligid ng 0.1 sa 0.2 ohms para sa isang 32 amp system.
4. Pagkatapos ay suriin para sa pagpapatuloy sa pagitan ng bawat pin sa plug at frame / engine lupa. Ang meter needle ay hindi dapat ilipat (walang katapusan na pagtutol) (ang mga digitals ay magpapakita ng walang katapusan na pagtutol) kung ang meter needle ay lumipat (na nagpapahiwatig ng pagpapatuloy) (ang mga digitals ay magpapakita ng paglaban), maingat na maingat na suriin muli. Kung ang metro ay nagpapakita pa rin ng pagpapatuloy sa lupa ang stator ay shorted (masamang).
5. Itakda ang metro upang basahin ang mga boltahe A / C na mas mataas kaysa sa 30 volts (ang setting ng scale para sa boltahe ay dapat palaging magiging mas mataas kaysa sa pinakamataas na boltahe na inaasahan mo o maaari kang magprito ng metro). Simulan ang bike, at sukatin mula sa isang pin patungo sa isa sa plug (HUWAG i-cross ang multimeter probes - pindutin ang mga ito sa bawat isa). Dapat mong basahin ang halos 16-20 bakat bawat 1,000 rpm.
6. Kung ang baterya ay mabuti sa ilalim ng load test, kung ang stator ay HINDI shorted sa lupa, at ang stator ay paglalagay ng A / C boltahe, pagkatapos ay ang regulator ay masama (malamang na kahit na ipinasa hakbang 2) Para sa karagdagang impormasyon tungkol sa iyong tanong at mahalagang "LIBRE" na mga pag-download na kakailanganin mo para sa pagtingin o pag-print mangyaring mag-click sa asul na mga link sa ibaba. Good luck at magkaroon ng isang kahanga-hangang araw. Stators Regulators Rectifiers What you need to know Video Guide Tip of the...
How to diagnose and repair motorcycle charging problems
XR200R service manual repair 2000 2002 XR200 Download Manuals Technical $15
https://www.partsfish.com/page/oem-parts-for-honda
http://www.hondampe.com.au/docs/owning_a_honda/owners_manuals/motorcycles/XR200R-1989.pdf
Apr 19, 2012 | 2002 Honda XR 200
Paano ko maa activate ung gprs ng cherry mobile cellphone unit ko
Hello Annalyndael,
You can do that by calling your mobile service provider and request them to activate it for you. Iba iba kase ang settings bawat phone and bawat service provider. Halimbawa sa Globe, iba ang settings sa Smart and iba din sa SUN. Kaya kapag ni setup mo yang phone mo for Globe GPRS, kapag nilagyan mo ng SMART na simcard, hindi din gagana ang GPRS.
So, tawag ka po sa globe/smart/sun or kung ano mang simcard ang gagamitin mo, tapos sabihin mo na ipapa activate mo yung GPRS ng phone mo. Dapat alam mo din yung model number ng cherry mobile phone mo para mas madali nilang ma-activate.
Pakirate naman yung sagot ko.
Thanks for using Fixya!
-damneddle
Oct 06, 2011 | Cell Phones
Anong mas maganda my phone b11 , b12 or b15 ??????????/
angel_gie3,
ang b11/12/15 ay mga basic functions lamang, kung gusto mo ng specs para ma kumpara:
http://myphone.com.ph/allprods.php
click mo ang model na gusto mong i-view ang specs para mag desisyun.
kung presyo ang importante, ang b11 ay pinkamura @ ~Php999
Aug 20, 2011 | Cell Phones
2008 Kawasaki Fury 125 ay hindi nagcha-charge
Hi, An2nyalan bago subukan ang anumang mga de-koryenteng sangkap sa Nagcha-charge System ito ay "IMPERATIVE" na mayroon kang isang ganap na sisingilin baterya ng 12.5 volts o higit pa at ma-ipasa ang isang wastong "LOAD" test kung kinakailangan, maaaring mayroon kang isang paunang pagbabasa ng 12.5 volts o higit pa ngunit maliit o zero amperage, ang baterya ay may mali at dapat mapalitan. Ang mga uri ng baterya ng AGM ay nahuhulog sa sitwasyong ito nang higit pa kaysa sa lead-acid na mga baterya.
Para sa karagdagang impormasyon tungkol sa iyong tanong at mahalagang "LIBRE" na mga pag-download na kakailanganin mo para sa pagtingin o pag-print mangyaring mag-click sa asul na mga link sa ibaba. Good luck at magkaroon ng isang kahanga-hangang araw. Kawasaki Fury Battery Charging Development
Kawasaki fury 125 manual pdf
OEM Parts for Kawasaki
http://mybikemanuals.com/kawasaki
Jul 23, 2011 | kawasaki Motorcycles
I have a 1 yr old samsung flat tv that has a sound but no picture..how can i fix it. i am in an isolated island here in basco, batanes philippines with no experts in repairing flat tv.pls advice. tnx
Kung LCD TV ang unit mo, 3 ang dahilan kung kaya la kang picture.
1. Me pundido kang backlight - kapag me pundido kang backlight kusang pinapatay ng power supply ang inverter board para hindi ma-overload kaya la kang picture. Maaring mong i-check ang backlight, ang palatandaan na ito ay pundido ay kapag me itim sa magkabilang dulo.
2. Sira ang inverter board - ang inverter board ang nagbibigay ng high voltage sa backlight. Kapag sira ito, natural d gagana ang backlight. karamihang sira ng backlight ay ang high voltage transformer, driver transistor o kaya me open na fuse/fusible resistor.
3. Power supply- kapag la supply voltage sa inverter board, la ka rin picture. Mas maganda kung ito ang sira dahil mas madali makhanap ng pyesa dyan sa lugar mo di katulad ng 2 nauna.
Kung me kakilala kang technician dyan malapit sa lugar nyo, patingnan mo yong mga sinabi ko. Maari ring dahil sa loose connection kaya la ka picture o kaya bad solder joints.
Salamat kapatid sa pagboto 4 na hinlalaki.
Jdvillanueva
Las Pinas NCR.
May 21, 2011 | Samsung Televison & Video
Walang image na lumalabas kapag nag capture ako sa digital camera ko,ang unit ay canon powershot a470
Ang isang mapagmataas panangga sa bintana ay isa pang karaniwang mode kabiguan para sa mga digital na kamera. Ang mga sintomas ng isang palalo o "malagkit" panangga sa bintana ay halos katulad sa kabiguan CCD imahen sensor. Ang kamera ay maaaring tumagal ng itim na mga larawan (para sa mga panangga sa bintana mapagmataas sarado), o ang mga larawan ay maaaring masyadong maliwanag at overexposed, lalo na kapag kinuha sa labas (para sa mga panangga sa bintana mapagmataas bukas).
Upang kumpirmahin ang isang mapagmataas panangga sa bintana, ilagay ang kamera sa anumang paraan maliban sa "Auto", at patayin ang flash OFF (hindi mo nais na bulag ang iyong sarili para sa susunod na hakbang). Susunod na tumingin pababa ang lens at kumuha ng larawan. Dapat mong makita ang isang maliit na maliit andap sa gitna ng lens bilang panangga sa bintana ang nagbukas at magsasara. Kung kilusan walang nakita, at pagkatapos mong malamang na magkaroon ng isang mapagmataas panangga sa bintana. Kung gayon, maaring tignan ang link na ito para sa karagdagang impormasyon at isang simpleng maayos na maaaring makatulong:
Ngayon A470 ay hindi kaya ng pagkuha ng 15 segundo exposures bilang inirerekomenda para sa ayusin. Sa halip na subukan ang mga setting ng kamera sa manual mode, patayin ang flash, got sa isang darkened room, at kumuha ng larawan. Buksan ang pinto baterya habang ang pula at dilaw na liwanag ay flashing. Kung pagkatapos ng maraming sumusubok na ito ay hindi gumagana, at pagkatapos isaalang-alang ang pagsubok Ayusin # 5a sa site. Subalit gawin ito sa kamera ang pinatay at ang lens retracted upang bawasan ang pagkakataon ng damaging ang lens na mekanismo.
Jan 24, 2010 | Canon PowerShot A470 Digital Camera
Vehicle Parts & Accessories Logo
87 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
