Question about Apple iPad Air
The screen is locked on my I pad air,how do I get it to respond?
The screen is locked, I tried rubbing it with 3 fingers and pressing the home button 3 times. When I do get the apple figure on the screen it seems to take a picture and off it goes black again. Voices tell me what to do but nothing works
John Privitera
    New Friend:
    Problem Solver:
  • 18 Answers
Turn it off then restart
Posted on Feb 24, 2015
RCA Android tablet. It has a crack across the screen. How do I unlock it? its got a pattern lock on it?
As far as I am aware you will have set the pattern lock.. It's usually a four digit code that you need to input by sliding your finger across a digital pad WITHOUT removing the finger from the pad until you've finished. If you can't remember the code try some possibles, remembering that you probably have a limited number of attempts before itr locks up you could also try settings on the android.
Jun 17, 2015 | Tablets & eReaders
Why am I unable to unlock my Zepad so I can remove photo on screen?
You have to format your device by Hard reset keys directly.
Procedure is very simple.
1.Turn off your Tablet PC by pressing Power Button.
2. Press/Long Holding Volume Down Button OR Volume UP Button.
3. Then Press Power Button to Turn on device
after that you will see factory resetting menu just select factory reset the pres Enter Or Yes.
Thanks
Nov 27, 2017 | Tablets & eReaders
My I Pad will not open to access my emails
You may have too many app open ... even after shutdown.
Double click the home button. The line at the bottom is all the open apps. Hold your finger on one of them until they wiggle with a "-" circle in the corner. Tap the circles to close them and open memory. Then try you Mail again.
Jan 27, 2015 | Apple iPad Wi-Fi + 3G - Tablet - iOS 4 -...
I have a tablet model number cmp743d my kids locked me out of my lock pattern and now it asks google name and password and I am locked out there too. Tried to reset with no luck. How can I fix it or do I...
1. Turn off your Craig CMP743d tablet by holding the Power button and selecting Power Off. 2. Simultaneously, hold the Back button and On button for 8 seconds. 3. When the android icon is seen already, press the Back button. 4. In the menu, just select the wipe/factory reset by pressing the Home button, followed by the pressing the Back button. 5. A new screen will appear. Select "Yes, delete all user data", then press Back button. 6. on the next screen, select "Reboot System Now" by pressing the Back button. 7. Just wait for your tablet to reboot.
Oct 08, 2014 | Tablets & eReaders
My I pad is frozen, how do I get it unfrozen
Hold the button on the back edge near the back camera lense for about ten seconds.
Sep 22, 2014 | Apple iPad 2
I am locked out dony remember the pattern when i try to do the pattern its only regonizing that my fingers is touching some of the dots?
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
This will reset you device to factory settings, however anything on your SD card will still remain.
At this point you will need to start fresh as if you just bought the device -- register with your email address, etc.
Nov 15, 2013 | Curtis Klu 7-inch Touch Screen Mobile...
I forget my pattern lock?so how will get return my password
You will need to do a factory reset:
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
Nov 02, 2013 | ASUS MeMo Pad Smart 10
Reset vigo android
This works with devices having physical home button:-
1. Press the power button and the home button together for a while, long enough until the screen appears with Android bot and a progress bar which shows that it's formatting the internal memory.
With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
or you can Check my blog how to reset your tablet lol,
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Feb 18, 2013 | Android Flytouch 3 8gb 10.1 Inch Super Pad...
Screen wont rotate ... How do I unlock
Double click home button
then scroll with your finger to the right look for first icon with a 3/4 circle with arrow tip that icon allows you to lock/unlock portrait mode
Mar 29, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Hi guys, during upgrade I did something wrong. So, now I have on screen of my tab logos of pc and mobile with triangle in between. No charging, non responding, no hard reset available. Please, help...
Have you tried the hard reset? Try these instructions for a hard reset:
The Galaxy Tab should then go through the hard reset process.
Mar 02, 2011 | Samsung Galaxy Tab Tablet PC
Apple iPad Air Logo
74 people viewed this question
Top Apple Tablets & eReaders Experts
John mullen
Shaukat Bhutto
Shaukat Bhutto
Nicola Conroy
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
