SOURCE: Spares for Breville Electric Kettle
Okay. I took the base off the kettle (made a special screwdriver). Saw that one of the contacts was loose on its 'swage'. Used a pin punch to re-swage it. Bingo! it worked.
Jeff.
SOURCE: Problems with Breville SK500XL Stainless Steel Cordless Electric Kettle
you need to change out the heating element.For electric kettle, alway remember to fill up water before you turn on the kettle.never poure water while the element was hot.hope it help.
SOURCE: new kettle breville
There's several home remedies you can try: Try 50% "White Vinegar", 50% Hot Water or 2 Denture tablets in warm water over night or Baking soda in warm water. These remove the alkaline, minerals, and nitrates that build up on the surface. There is even a commercial product you can use to clean it. I can't recall the name but look in any supermarket, you should be able to locate it.
SOURCE: Breville kettle blew fuse (trip switch) now won't switch on
If the 'neon' light is on, the power is getting to the kettle, so if its not heating up then the element must have broken.
This kettle has a little white trip switch inside the 'socket' of the kettle (not the base unit). If its not heating, light is not on and the plug fuse is OK, then poke the white trip until it clicks.
SOURCE: how do I clean
Fill kettle until 3/4 full with 1 part vinegar and 2 parts water. Boil and allow to stand overnight.
Empty solution from kettle. Fill the kettle with clean water, bring to boil and discard water. Repeat and the kettle will be ready for use.
Or you can use a proprietary kettle descaler, which is available at most hardware stores.
