I appreciate your inquiry, friend!
Based off the information you have provided your Frigidaire dishwasher is displaying an error code of "5H". That appears to be the time remaining on your wash cycle. Typically an error code would be displayed with a number and an "E". What is the current problem with your dishwasher? Are you getting long wash times? There is a sensor inside of your dishwasher that reads how dirty the water is, if your dishwasher continues to circulate dirty water it will tell that sensor to continue washing. You may want to check your filter, which is located at the bottom of the tub, for any debris. Additionally, if your drain hose is restricted it may be providing dirty water back into your tub. I hope this information is helpful to some degree. -Matt
It is a French door refrigerator.
SOURCE: diswasher
Not at this time there not. The panel would have to be custom made. That would be very costly.
SOURCE: I have a frigidaire dishwasher FDB2415LFSO white
The dishwasher panel is easy to change. You can get cheap stainless panels at www.applianceart.com. They have kick plates too
SOURCE: I am looking for a stainless steel replacement
Go to www.applianceart.com. Cheapest options. Have real stainless and faux stainless and will make sure you get the right size.
SOURCE: is it possible to change door panel for
YES! go to www.applianceart.com they have hundreds of options (including stainless) for your dishwasher.
SOURCE: Frigidaire Signature Series Stainless Steel
That
is not that hard to fix and you can easily buy the parts yourself
online...
Here is a tip that will help you with the online
buying...
How to Buy Appliance
Parts Online
heatman101
Hello - Could it possibly be HI? Typically error code HI indicates that the unit has detected high temperature in freezer. Try setting the unit to a lower setting. Generally the factory setting is 0 for the freezer temperature and 37 for the fresh food temperature.
