Sounds like the fuel injectors or fuel pump. Have you tested the pressure when it isn't running?
Also, the fuel filter, has it been changed?
A clogged fuel filter would cause a 'lack' of gasoline rather than too much, as is the case with a stuck open injector.
I also think that since it does it only when hot, that a sensor related to heat is giving a faulty value. For instance, if the cts (coolant temperature sensor) is stuck at a certain value or false value, then the vehicle could start malfunctioning due to this.
However, I think that if the car is doing this intermittently, then there might be engine codes stored in the obd-II computer scannable with a scanner for OBD-II.
Do you see a service engine soon light at any time while the engine is running?
A bad fuel pump would be a good place to look if it happens when the tank is 1/4 full. There could be sediment in the bottom of the tank with that much age and mileage.
Fuel Injection
General Information
Electronic fuel injectors for all gasoline engine applications are basically the same. They consist of an injector body, an electric solenoid, spring, nozzle and a filter. The injector receives a constant supply of pressurized fuel from the fuel system. The primary function of the fuel injector is to atomize gasoline into the surrounding air, at the proper time. Throttle body injectors atomize fuel into the intake manifold in much the same manner as a conventional carburetor (wet intake). Port fuel injectors direct the atomized fuel at the backside of each cylinder's intake valve(s) (dry intake). Gasoline direct injection systems operate at substantially higher pressure and direct the atomized fuel directly into the combustion chamber of each cylinder.
Basic Fuel System Diagnosis
Two of the most import diagnostic checks, when dealing with a driveability problem involve the ignition and the fuel systems. The questions most technicians attempt to answer first are "is there spark?'' and "is there fuel?'' This often leads to solving most basic problems. For ignition system diagnostic testing, please refer to the information on engine electrical components and ignition systems found earlier in this manual. If the ignition system checks out (there is spark), then you must determine if the fuel system is operating properly (is there fuel?).
