Question about Comfort Zone CZ7007 Oil Filled Electric Radiator Heater
I have been using my heater in the garage to prevent my water pipes from freezing. It just quit working today. The lights do not light and it will not heat any longer. What happened and what can I do to fix it?
Posted by Susan Decker on
ka9ior
    Habit-Forming:
    New Friend:
  • 54 Answers
Have you checked the circuit breaker or fuse for the circuit that your heater is on? It's possible that you had something else come on that, combined with the current draw of your heater, popped the breaker. If that turns out to be the case, turn the heater switch from high to medium or from medium to low so that you're drawing less current.
Posted on Feb 24, 2015
Testimonial: "The night light plugged into the same outlet was still on, so I know the circuit had not been broken."
I have a greenstar boiler its 16 mths went out today blue light flashing checked the condensation pipe was frozen have cleared it out the flue looks ok but im 72 years old its snowing and its bitter
The condensate pipe must be piped into an interior drainage pipe or it will freeze. Turn off the red emergency burner switch to reset the boiler. Also make sure that your flue pipe is clear of snow and doesn't have residual condensate freezing up and blocking it. If it is not pitched back to the blr, it can freeze and clog the flue. This will cause your press switch to cut out on high pressure.
Mar 01, 2018 | Water Heaters
Gas heater fills, lights and water pipe is hot. Only luke warm water dispenses. Have replaced thermostat/gas control and thermocouple. What now?
make sure that you do not have a water temp mixing control valve in the out let pipe from the system
that is a safety requirement that stops the hot water from going over 70 C to prevent hot water burns
Jan 28, 2018 | Water Water Heaters
Daughter while driving temp light came on. However less then 3 days ago had all fluids and oil changed any thoughts?
Hello, if the water in the radiator was quite low, before topping up, there could be an airlock in the system. Does the internal heater blow hot air? If it only blows cold air, even when the control setting is set to hot this indicates either low water level or air lock in the heater matrix or pipe feeds to it. Quite a few models have bleed valves on the pipe runs under the bonnet just before the bulkhead.
Hope this helps you.
Oct 04, 2015 | Cars & Trucks
How do i eliminate moisture from an underground,natural gas galvanized gas line. I have no gas flow to my garage or my 75k garage heater.
Check on the local codes governing gas piping, but it would be my suggestion to consider abandoning the existing line IF you are sure there is a compromise to its integrity allowing water to enter. I would think if water ENTERS...then GAS has to be able to excape. It'd be a lot of condensation that's required to either just block the line or freeze and block the line. If it freezes due to lack of depth, it's going to rupture anyway sooner or later necessitating replacement.
At the above ground location before where it goes subterranean, (after checking the codes), consider installing the appropriate brass fittings to then allow a new underground copper line to be installed by attaching by means of an iron pipe to flare adapter in the appropriate size. Then utilize type L soft roll copper to lay in the new trench to the garage and tie it into the existing line inside the wall. Type L is the thick walled soft tubing and can be used in many locations for gas, whereas Type M soft copper tubing is thin walled tubing for use with water and not gases. Your area may not allow it. That's what building inspectors are for.
Before proceeding, MAKE SURE your line is in fact the problem then double check with a local authority whether or not copper materials are recommended along with brass fittings for the connections. IF the original and suspected problematic gas line is for sure GALVANIZED it is not in any way approved for use with natural gas. It is probably black iron pipe.
Jan 03, 2015 | Heating & Cooling
If i insulate my pipes, will it stop them from freezing the water? This problem has been happening a lot this winter, it is colder than usual where I live.
Insulating your pipes won't stop the water from freezing but it will take a much longer time for the water to freeze, so it defintely helps a lot. I would do it if I were you.
Jan 31, 2013 | Insulation
Mhu 75, only one burner lights
did you put a drip pocket on the line to the heater
Apr 05, 2012 | Mr. Heater MHU75NG
Have hot/cold water pipes coming outside from roofspace in house to garage for washer/dryer. Already had two bursts inside garage and machine and electrics destroyed. New machine installed after...
Insulation only slows down the transfer of heat (cold), it does not stop it. If it is below freezing and the water in any pipe is not moving, it will eventually freeze. Most major industrial supply houses like McMaster-Carr or Grainger in the US, carry pipe tracing tape. It comes in various lengths and you secure it to the pipe under the insulation, plug it in and many types have integral thermostats that keep the pipe above freezing. If you have a washing machine, you will have to consider the lines to the washer valves, both hot & cold and any other areas in the washer that may hold water like the pump and the discharge hoses.
Was this washer always outdoors?
Jan 08, 2011 | Easy Heat Water Pipe Heating Cable
Can't get hot water heater to work - Rinnai Infinity 18
If you can get to the gas valve make sure it is in the on position and not in pilot or off. Does it sound like
a spark ignition system? Even though you say the gas valve is on, by code thered should be a gas shutoff valve located within site of the unit. Follow the
gas pipe until you find such a valve and make sure its on
Feb 07, 2010 | Rinnai Vent Free Gas Heater/
Creda T620CW condenser dryer
Recently bought condensor dryer which was working fine till the very cold weather came. Is situated in the garage so temp has been going well below freezing some nights. Now keeps switching off after a few minutes and empty water light flashes although resovoir has no water in it. Is this due ti pipes freezing?
Jul 26, 2008 | Dryers
Comfort Zone CZ7007 Oil Filled Electric Radiator Heater Logo
219 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Marvin
Marvin
Paul Carew
Muntejaya Ginting
Muntejaya Ginting
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
