Question about Motorola CLS 1110 (1 Channel) 2-Way Radio
I am trying to change the channel on my radio, how do I do that?
Posted by robsrage on
eradiostore
  • Motorola Master
  • 1,667 Answers
The CLS1110 is a one channel radio. However the one channel can be changed to another frequency and/or PL code. With the radio turned OFF, hold in the PTT and the MON, while turning the radio on. Continue to hold the PTT and MON until the radio stops making noise. You are then in programming mode and can use the menu button to walk through the stages of programming. Use the PTT to change the settings, and the MENU to lock it in.
Posted on Jul 09, 2009
How do I change channels on my Maxon 49-sx
  • The "Maxon 49-SX" is a single channel transceiver that only operates on 49 MHz FM. The Maxon "49-FX" and "49-HX" operate on 5 adjustable adjustable frequencies. That radio has no channel/frequency options.
  • Hope this helps.
I cannot hear anyone else on my channel, also the others on my channel cannot hear me. we are using channel one
this seems to be an electronical problem with your WT; in fact, i suppose it does not select the right channel; you can try with 2 WT, one stuck on a channel, the other try to change channells and talk
My maxon cb radio model MCB-10A wont change channels it stays on channel 9
Hi, my name is John. Try to press or flip the button or EMG. That should do the trick.enjoy....hope this was very helpful....
Stuck on channel 9 wont change
Try pressing the emerg. or Cha.9 button....hope this helps...
4helpful
My cls 1110 walkie is stuck on channel 1, how can i change it?
Can't Change Channels
you can try and ring 01388 778368 ask for steve and he may be able to help.
Wont change channels...stuck on channel 8
on this radio you have to put the norm and channel 9 switch to normal or up if it is on ch 9 positon it will not change channels.
2helpful
2answers
Talk about frequency change
To change channel & code press talk and monitor while turning radio on. Radio will speak current channel. Release both talk and monitor. Press talk to change to next channel or press monitor to keep current channel. Press monitor when desired channel is selected, radio will speak current code. Press talk to change to next code or press monitor to keep current code. Press talk to change code as desired then press monitor when done. Will speak channel and code selected. Set all units in same manner to communicate.
Green light blinks
On my two channel radio a blinking green light means that it is scanning between the two channels. I can turn off the scanning and the light stops blinking.
Motorola CLS 1110 (1 Channel) 2-Way Radio Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
