Question about Ice Cream Makers
Owners manual,recipes for B&D Arctic Twister IC200
Have a B&D Arctic Twister IC200 but no owners manual or recipes
Posted by Jo An on
  • 2 more comments
  • mamatthews Jul 06, 2008
    I ned an owners manual and recipes
  • juanitamailm Jul 19, 2008
    i have the B&D arctic twister ic200 with no manual or receipes
  • musicmamma Oct 01, 2008
    I need an owner's manual for the B&D arctic twister if anyone has one or knows the link to get a pdf.  Thanks!
  • jakehoover Dec 24, 2008
    i cannot find my recipe book and i want the recipe for the easy vanilla ice cream,
4 Related Answers
Anonymous
SOURCE: Arctic Twister
Thanks Healthe!
Posted on Dec 31, 2007
Anonymous
SOURCE: no instuctions for my arctic twister which was given to me as is
This product wastes a lot of ice cream in its mechanisms. I would not reccomend its use to anyone who believes in "waste not..."
Here are the instructions for any wasteroos who would still use this product:
Série IC200 Series
Arctic Twister™
Ice Cream Mixer
? U.S.A./Canada 1-800-231-9786
Mexico 01-800-847-2309
www.blackanddecker.com
To Assemble the Ice Cream Mixer:
1. Insert the Twister firmly into the opening on the
Base (A).
2. Slide the Chute/Dispenser over the Twister along the runner
on the Base (B); it will click into place.
Note: Unit will not operate if Chute/Dispenser does not click
into place.
3. Hold the Lid with Ratchet Clip in one hand with the Handle
facing front. With one finger, push the Ratchet Clip on the Lid
forward. In other hand, hold the Plunger with smooth side
facing front, and from underside of Lid, insert Plunger into
Clip opening (C), pushing Plunger up until the Ratchet Clip
rests on top of the Plunger base.
4. Set aside the Lid with Plunger in place. Now you're ready to
start mixing up some fun and delicious ice cream treats!
To Use the Ice Cream Mixer:
Assemble all ingredients before you begin to make your first
batch of twisty treats: Set out an ice cream scoop, the mix-ins
you plan to use, ice cream cones, cups or dessert dishes,
then bring out the ice cream.
For best results, use hardened ice cream, frozen yogurt,
sorbet or sherbet directly from the freezer.
You may want to rinse off the Lid, Plunger, Chute/Dispenser
and Twister before beginning new ice cream flavors or
mix-ins.
Always wash Lid, Plunger, Chute/Dispenser and Twister
between batches, if you have been using ice cream or mix-ins
containing peanuts, to prevent accidental peanut
consumption by those who may be allergic to them.
1. Plug the Cord into a standard 120V wall outlet.
2. Position a flat-bottom cone, dessert dish or cup under the
spout of the Chute/Dispenser.
3. Place 1 scoop of store-bought ice cream into the
Chute/Dispenser. Sprinkle in 1-2 tablespoons of the mix-ins
(see "About Mix-Ins"); add another scoop of ice cream, and
continue layering as above, ending with ice cream, until
Chute is filled.
4. Fit the Lid with Ratchet Clip and Plunger in place (see
assembly instructions #3 above), onto Chute opening,
pressing down slightly and turning the Lid to the right to fit
into position, then to the left to lock it into place on the Chute.
5. Gently pump the Handle up and down a few times to "prime"
the Chute.
6. Press the On/Off Switch to "on" position, then slowly pump
the handle to move ingredients down the Chute. As you
pump the handle, the ingredients will automatically be moved
into the Twister, then out the spout of the Dispenser.
7. When the Chute is empty, turn On/Off Switch to "off" position.
Push the Ratchet Clip forward and pull up the Plunger, then
use the Handle to move the Lid to the right. Lift the lid with
the Plunger in place out of the Chute.
8. Repeat steps 2-6 to make as many batches as desired.
Posted on Jul 28, 2009
Lance Hill
  • 1739 Answers
SOURCE: where do i find black and decker ic200 arctic
One source is Amazon.com:
http://www.amazon.com/Black-Decker-IC200-Arctic-Twister/dp/B000063XHF/ref=sr_1_7?ie=UTF8&qid=1301023085&sr=8-7
If you searh on-line you can find many on-line stores that carry the product... The Amazon site also has a link to the Use & Care Guide.
You may also want to look at some sites that provide reviews:
http://www.epinions.com/review/Black_Decker_IC_200_Ice_Cream_Factory_Soft_Serve_Dispenser_Small_Appliances/content_123640581764
Posted on Mar 25, 2011
Lance Hill
  • 1739 Answers
SOURCE: need owers manual arctic twister
The Use & Care Guide for the Black & Decker IC200 Ice Cream Mixer can be found here:
http://useandcaremanuals.com/pdf/IC200203.pdf
Sorry someone has not responded sooner.
I need the manuel book
The Use & Care Manual for the Black & Decker IC200 Arctic Swirl Ice Cream Maker may be found online here:
Dec 02, 2011 | Black & Decker IC200 Arctic Twister 2.11...
Black & decker arctic twist. that part where you put the ice cream in, it broke off where you insert to the machine. is that part sold seperately ? if yea, how long will it be to ship to Port Hardy...
Available parts for the Black & Decker IC200 Arctic Twister 2.11 Quart Ice Cream Maker can be found here.
http://www.directpartsandproducts.com/other-ic200-c-1_1486_1691.html
If what you require is not listed call the posted telephone number: 1-800-738-0245
Sorry it has been so long for someone to answer your questions.
Sep 07, 2010 | Black & Decker IC200 Arctic Twister 2.11...
I need a little help working a black decker arctic twister
The Use & Care Guide for your Black & Decker IC200 Arctic Twister 2.11 Quart Ice Cream Maker can be found here:
You did not specify your problem but if the maula is of know help perhpas you may find it useful to read some reviews on the product:
http://www.epinions.com/reviews/Black_Decker_IC_200_Ice_Cream_Factory_Soft_Serve_Dispenser_Small_Appliances
http://www1.dealtime.com/Black-and-Decker-IC200/know-what-you-are-getting/RD-467874909828/reviews
Jul 17, 2010 | Black & Decker IC200 Arctic Twister 2.11...
I have lost the manual & instructions. Is there any way I can get a copy?
Jun 19, 2010 | Black & Decker IC200 Arctic Twister 2.11...
I need ins. and res.
The Use & Care Guide for the Black & Decker IC200 Arctic Twister Ice Cream Mixer can be found here;
Sep 06, 2009 | Black & Decker IC200 Arctic Twister 2.11...
Need to know how to use it and what to put into it to make ice cream
This product is used to turn store bought ice cream in to soft serve with added treats.
The Use & Care Guide for your Black & Decker IC200 Arctic Twister Ice Cream Mixer can be found here:
See page 2 of the pdf for instructions on how to use.
Jun 28, 2009 | Black & Decker IC200 Arctic Twister 2.11...
Need instructions
You get the instructions here, they are in three languages, right side is English :
Arctic Twister
Oct 15, 2008 | Black & Decker IC200 Arctic Twister 2.11...
Need a book or something to show me how to use your black and decker arctic twister. When I brought it there wasn't one.
If you go to www,useandcaremanuals.com/pdf you can download the entire manual. Hope you enjoy your arctic twister. I hope this helped.
Jul 24, 2008 | Black & Decker IC200 Arctic Twister 2.11...
Ice Cream Makers Logo
439 people viewed this question
Top Ice Cream Makers Experts
Marvin
Marvin
ray gallant
Tom Chichester
Are you an Ice Cream Maker Expert? Answer questions, earn points and help others
