After replacing ink cartridge printer dose not reconize one of six
Posted by mrwee on
Anonymous
    Sniper:
  • 54 Answers
Using refilled in cartridges and incompatible inks result in the following problems.
  • Refilled ink cartridges might leak and cause product damage. One method for refilling ink cartridges is to drill a hole through the cartridge, refill the ink, and then plug it. In some cases this plug does not hold, and the ink runs into the product and damages the printed circuit boards.
  • Refilled ink cartridges frequently exhibit spotty printing or fail to print. This problem might be a direct result of the nozzles being plugged with dried ink. Because the vents of the refilled cartridges have been opened, air is able to enter the cartridge and dry the ink.
  • Refilled ink cartridges might exhibit lower print quality, for the following reasons.
    • Printing algorithms used to create the various colors are based on particular printer inks. Using incompatible inks might result in color matching problems.
    • Refilled cartridges might have damaged nozzle orifices, result in various problems with print quality.
    • company products to which the printer belongs to can use a time delay between pages to accommodate the properties of the specific media type and ink being used. This prevents smearing problems from one page to the next. Using incompatible ink will alter the effects of this time delay and might result in poor print quality.
  • printer might not recognize refilled ink cartridges. The refilling process may involve altering the ink cartridge enough that the product is unable to recognize it. The condition of the print cartridge electrical contacts deteriorates with use. This also results in the product being unable to recognize the refilled cartridge.
  • Refilled ink cartridges might get stuck in the product. Because the cartridges from other manufacturers have been altered, cartridges might become stuck in the product. This problem might require that the product be disassembled to remove the cartridge.
  • printer at times cannot predict the long-term effects on product reliability from using different ink formulations.
try this.
please rate my solution.
have a nice day.
Posted on Jul 08, 2009
Manoj Rout
  • 495 Answers
Could you pls try checking if you have properly placed all the catridges. Also try restarting the printer.
Epson Artisan 1430 Inkjet Printer ink cartridges not reconized
If it is not reading one particular cartridge please try the following as it has worked for us 90% of the time.
  1. Remove all ink cartridges
  2. use a pencil eraser on the chip of the unreadable cartridge.
  3. install the cartridge you just used eraser on.
  4. if printer accepts cartridge, turn off printer.
  5. turn on printer and install remaining inks
This should solve the unreadable problem.
This is fairly common problem, usually effecting compatible units.
Jan 27, 2015 | Epson Office Equipment & Supplies
I have a 926 series dell printer...changed color cartridge and my computer will not reconize it..still says I am out of ink.
Most likely the new cartridge is defective. Most cartridges contain chips and these are occasionally bad. See if the retailer will exchange it for you.
Oct 05, 2014 | Dell Office Equipment & Supplies
Epson sx430 dont reconize cartridges
If it has been there for ages then probably it's already not functioning properly and needs a replacement :)
Your Epson printer doesnt recognize the Ink Cartridge Heres what to do
Apr 04, 2013 | Epson Stylus Office Equipment & Supplies
Just replaced cartridge and it says m69 cannot reconize ink cartridge
Please re-fit your new cartridge securely while disconnect the power. It seem your cartridge is not in correct place. Check also all wires for loose connection
Jan 05, 2011 | Epson Stylus CX9400 Photo Printer
On Epsom Stylus NX110 I cannot get the cartridges to the change position If I go into cartridge replacement utility I cannot open that and do not have a printer in the lower right hand corner to access...
Here is what I found on Epson Web site. Click on link below. IF YOU FIND THIS HELPFUL PLS RATE ME. THANKS AND GOOD LUCK......
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=128285&prodoid=63083739&category=Products
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Replace Cartridges Using a Printer Software Utility
For best printing results, use up a cartridge within six months of opening the package. If you need to replace a cartridge when the ink light is flashing or off (before the cartridge is expended), you can run the Ink Cartridge Replacement utility.
1. Windows: Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Printer Settings. Click the Maintenance tab.
Macintosh: Open the Applications folder, open EPSON Printer Utility3, select your printer (if necessary), and click OK.
You see one of these screen SEE ATTACHMENT BELOW
2. Click the Ink Cartridge Replacement utility icon and follow the on-screen instructions to replace your ink cartridges as necessary
Mar 21, 2010 | Epson Stylus NX115 All-In-One InkJet...
How to change ink cartridge in epsonnx110
Jan 01, 2010 | Epson Stylus NX115 All-In-One InkJet...
Finding correct Cartridge ?????
#14 black #15 color it has to be lexmark ink only...it will not accept any others.....if you have a walmart where you stay at they should have a little machine by the ink cartridges....use that...that is where i got this info from and my printer is printing just fine
Nov 13, 2008 | Lexmark X2500 All-In-One Printer
Refilledandreplaced ink caritaartages and prnter doesnt reconize
You say you have refilled the ink carts. Have you reset the chip on the cartridges? If not the chip will still report the printer that the carts are empty.
Feb 27, 2007 | Epson CX7800 Stylus Color All-In-One...
1,272 people viewed this question
Marvin
Marvin
