On the Menu Screen, I'm not able to click on the "Lock" mode or "Channel" mode
SOURCE: after lightening zap
Call your insurance agency as this should be covered under your homeowners policy. The main driver board is made by JeanCo of Taiwan and is not replaceable and cannot be ordered as a part.
Good luck
SOURCE: Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
SOURCE: Tv appears to be stuck in auto-detect mode
All I can suggest is press down and hold your menu button on the remote and roll around in circles.Also try it with the menu button on the TV.It definitely sounds like it is being pushed down enough to be stuck.If that does not work please write back and in the meantime I will research it a little further.Bought in March huh?90 day waranty too I bet?How long has this been going on?If it does not work,I am also providing a link to Samsung to contact them.You will need probably model number and serial number.If you have the receipt,registered it,or have a credit statement to show when you bought it,and you are really persistent,they will usually do something about it.Samsung is supposed to be one of the best TV's too.I am surprised by this issue.Good luck!
http://www.samsung.com/us/info/contactus.html
SOURCE: I need to do a
During power up and first time use, there should have been an option for channel scanning as the initial setup wizard began.
Alternatively, there should be a way to navigate to the channel scanning menu by selecting, Menu>TV>Auto Channel Search. I couldn't get the exact info from the model you listed, but I gathered this info from a similar owner's manual (lc-32sb28ut) from the Sharp webpage: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Hope this helps.
