Question about Toshiba E-Studio 356 Multifunction Copier
Toshiba Copier E-Studio-356SE Bypass Problem?
Toshiba e - 356SE when you put paper in the bypass, after withdrawing the paper Job Status is blinking. And the status of the machine, see the paper is sspnd States. You want to take single or multi-copy, paper comes out the same job status is blinking. The paper comes out
5 Related Answers
Morné du Randt
  • 76 Answers
SOURCE: how do i get the bypass feeder to start printing
put the paper in the bypass and select paper type.
Posted on Oct 06, 2009
nonontech
Lebanon Raingam
  • 4737 Answers
SOURCE: I have printed this file many times, sent file to
Try this, Press the Cancel button several times, leave it for few minutes, and then Turn off and switch on while you keep pressing the cancel button. If there's memory installed on the Dimm slot, remove it and re-install it.
Also check the print queue, Start > Printers and Faxes > double-click the printer's icon, click "printer" on the menu and select "Cancel all Documents" click "Ok" and restart both computer and the Machine. (I assume your computer with windows Operating System Installed.)
Sometimes reseating the cartridges and drum is helpful. You can give a try. But since you can make copies, I don't suspect the issue's related to the machine, but with the computer and memory.
Disconnect and reconnect the cable (usb) connecting the machine to the computer.
Good luck.
Thanks for using FixYa.
Posted on Aug 13, 2010
tonesmaker
A.Hadi
  • 60 Answers
SOURCE: There is a display message
try to format its HDD :
turn it off..
hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again or enter . Wait for it to say "please reboot the machine", turn it off and back on. Hopefully this will work..
Posted on Jul 08, 2011
Victor
  • 44 Answers
SOURCE: What does job status code
It's an E-mail related error message. The message is exceeding the file capacity. Reset and extend the message size limitation or reduce the number of pages and try the job again. Hope this helps
Posted on Jul 20, 2011
gelkins360
SOURCE: My toshiba copier keeps saying job status change
my toshiba e studio 351c keeps telling me to join finisher to copier
Posted on Aug 12, 2011
Bypass feed
this is set by the computers driver
or its detecting no paper in the main drawers
Jan 10, 2015 | Toshiba e-Studio 350 Copier
HOW DO I PRINT A BROCHURE
You can put special media on side bypass feed tray. Then select paper type/thickness. Choose the bypass tray and paper type when sending print job from your PC. Job status light will blink and you need to go to the copier to execute the print job for special paper.
Sep 26, 2014 | Toshiba estudio 255 Copier
Printer hangs
check touch screen job status. this particular user might not have the setting configured properly on his pc and affected all job queue due to paper size not avail in any drawer or bypass paper needed.
to release the rest of the job queue, just delete the job pn the touch screen. u can see the delete button on the touch screen when u press job status
Mar 20, 2014 | Toshiba e-studio 455 Copier
Error code E030 on toshiba E-Studio 282 copier
See where the paper jam...if no paper found, check the 2nd transport sensor locate at bypass unit, probably is faulty
Aug 13, 2012 | Toshiba Office Equipment & Supplies
There is a display message that comes up when you press the job status button that is flashing "Check the direction or the size of the paper on the bypass tray and press start", we are not trying...
turn it off..
Jul 05, 2011 | Toshiba e-studio 455 Copier
I have Toshiba photocopier, Studio 455. i want to print one page label paper. Should i use a bypass, which i tried but did not work. Tell me how.
If you are printig labels you MUST use the bypass tray on the right side of the copier. You mst specify heavy or card stock/label paper so it will fuse properly. I can't tell you why the tray does not work? But labels must be run thru the bypass.
Good Luck and Thank You for using Fixya.
Sep 14, 2010 | Toshiba e-studio 455 Copier
My toshiba copier keeps saying job status change paper type. how do i get it off that? thank you
Your copier is likely trying to print to a different thickness of paper (ie thick 1/thick 2) then you have in whatever tray it is trying to print from. You will either have to change what is in that drawer via user functions or delete the job and try it again with a different paper type.
Sep 07, 2010 | Toshiba E-STUDIO 720 Copier
Make A3 Copy (Toshiba Studio 206)
If your copier didn't set any A3 drawer, then u need to insert A3 paper on bypass unit, on left panel select A3 (Original) to A3 (copy) b4 u press the start button. Otherwise paper jam will occur.
Apr 05, 2010 | Toshiba e-Studio 205 Copier
Toshiba E-Studio 356 Multifunction Copier Logo
261 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Timothy Van Der...
Muntejaya Ginting
Muntejaya Ginting
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
