Question about Health & Beauty
How do I paint my finger nails perfectly?
I always try to do a perfect manicure but it never quite works out that way. Its always lumpy, or it doesn't dry correctly.
Jayme Smotony
    New Friend:
Take your time. Try rubbing vaseline around your nails so the polish wont stick to your fingers
Posted on May 13, 2015
R.Karthikeyan
  • 122 Answers
Use cellotape or inch tape wrap around nails and color the nails and peel off simple and cheap
Posted on Mar 23, 2015
Tip
Tip To Remove Nail Paint Easily !
Have alook at some of the easy and handy ways to remove the nail polish.
1. Dark nail color
Taken aback? Well it is true! If you have a deeper shade of nail paint than the one existing one, you can use it as a paint remover. Apply the darker paint to your already painted nails generously and immediately remove it off using cotton balls. Make sure to be quick in doing it so that the paint does not have sufficient time to get dried.
2. Perfume
Love to wear perfume? Well, here we give you have another reason to buy them. Regular perfume will help you a lot in getting rid of your nail color. All you need to do is dip a cotton ball in a generous quantity of perfume and gently rub the painted nails with this. This requires not much pressure and one can get their nails paint-free instantly.
3. Body Spray
If you happen to find the bottle of your nail remover empty, consider the bottle of your body spray for the same purpose. Place the bottle in such a way that the nozzle remains just a few centimeters away from the nail. Now, spray it on your nails and slowly wipe off your nail color by using cotton ball. Repeat the same process for all other nails.
4. Dry cloth and warm water
Take some warm water and put the fingers in it. Wait for the polish to soften enough (this should take about 20 minutes), and then, take out the fingers from the water. Using a dry cloth, gently rub the nails. The color will disappear.
5. Vinegar and lemon juice mixture
Replace the acetone-filled polish remover with a very easy and simple home remedy which is safe. Take 1 tablespoon of lemon juice and mix 1 tablespoon of vinegar to this. Blend both well together. Then, dip a cotton swab into this mixture and gently rub the painted nails using this. Spending about 10 to 15 seconds on each nail will remove all the traces of the old polish efficiently.
on Jul 15, 2016 | Health & Beauty
Used filler for filling nail heads rubbed back next day perfect two weeks later painted wattyl undercoat water base and filler went soft
The wood filler, a water based product, pulled the water out of the latex paint and softened. To preclude this in the future, you can cover these repairs with shellac or another sealant to provide a barrier between the filler and the paint. Spray shellac is available in hardware stores, and is used on water stained ceilings before repainting.
May 20, 2015 | Timbermate Wood Filler Water Based 8-oz...
Painting cabinets
I've heard the best method for painting cabinets is removing all lacquer off the wood and removing the handles for a more thorough job. I don't think it get's much more complicated. You could always <a href='http://aaaactionpainting.com/commercial/' > hire someone</a> to do it, I think it'd be pretty cost effective.
Jan 26, 2014 | YouTube Videos
How can you do your own nails at home? Are there any special tips?
Take a look at this YouTube video that shows how to do an at home manicure; it's quite a long video but it really helped me;
http://www.youtube.com/watch?v=B4bqpihDPnA
Feb 25, 2013 | Health & Beauty
Hitachi roofing nailer shoots every other nail & doesn't sink the nails it shoots
i think you have two different problems , replace the feeder spring, and replace the oring on the driver piston. also make sure that the coil of nails is perfectly round if they are dropped or squeezed tool will not work right
Sep 11, 2012 | Hitachi NV45AB2S Coil Roofing Nailer
Can not find revlon blackberry #751 nail polish. What happen? Its my favorite. Where can i order it ?
Finger Paints ' What an Exhibition', available at Sally's Beauty Supply, is a perfect match for the discontinued Revlon Blackberry!
Aug 24, 2012 | Health & Beauty
I need part for a SFN6 DEVILBISS NAIL GUN
I found a solution to the discontinued check seal part #nsp-199.I can get one that is a perfect fit.
Jun 22, 2010 | Itw Devilbiss Itw Paslode Cnp 65Y Coil...
Health & Beauty Logo
910 people viewed this question
Top Health & Beauty Experts
ray gallant
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Health and Beauty Expert? Answer questions, earn points and help others
