Question about Sharp Office Equipment & Supplies
Get a serial key for a sharp print ar 122en
Digital
Bertus
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Sharp Expert
  • 177 Answers
Serial numbers of all Sharp Copiers are located on the rear right-hand side of the copier , on a silver sticker
Posted on Feb 24, 2015
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
HI, my copier AR-122EN is not working it shows 4 and H when I press he start button.
From the keypad area press # * C * The machine will enter a diagnostic mode.
Then enter the number 14 as if to make 14 copies. Press start and follow the directions to clear the code.
Mar 11, 2011 | Sharp AR-5316 Advanced Digital Imager...
How to reset sharp ar 122en
Hi, to reset the problem signs or codes, key in the following in this order and a speed of a second per key press;
  • C Auto C Auto, display must go off or blank.
  • Enter desired code followed by Copy key press. Others have sub-codes and will require you to press Copy key again after that sub-code. For example H2,H3, U2 and H4 needs once Copy key press while developer or maintenance signs require pressing 20 then Copy key then 01 then Copy key.
Hope i have adequately answered you.
Jan 22, 2011 | Sharp AR-5316 Advanced Digital Imager...
MY SHARP AR-5316E DISPLAYS H4 AND IS NOT WORKING
Dear friendscom, H4 :Heat roller abnormally low temperature.
__ possible cause __
  • Thermistor failure
  • Heater lamp failure
  • Thermostat failure
Perform the following procedure to reset the code:-
"#" key-- Interrupt key-- "C" key --Interrupt key--14--print
Jan 12, 2011 | Sharp AR-5316 Advanced Digital Imager...
Drivers for sharp AR122en
Hi there, you can get it if you buy a new copier which has inbuilt printer board. If you bought the printer board separately, you can download it from the internet.Please follow these steps:
  1. Go to Google.com and open.
  2. Type free drivers for sharp Ar 122en.
  3. Select your operating system for example Windows xp and click that link on the right.
  4. Enter Code from image as shown and click download file.
  5. You will see 'Click to download sharpar122en570.zip' click it it and a small window will appear and select whether to save or open. A download window will appear and wait till it completes.
  6. You can us or write it to a CD for future use.
All the best.
Nov 16, 2010 | Sharp Office Equipment & Supplies
Printing from a mac OSX.5.8 to a Sharp copier AR BC320?
You will need to purchase the Post Script Driver for that model. Sharp Copiers require a product key code to enable post script on their copiers. A sharp dealership will have to sell it to you as well as to get the product key code for the postscript driver.
Dec 10, 2009 | Sharp AR-BC320 All-In-One Led Printer
Sharp reset developer on ar-122en
I do not understand What is step by step help?
Focus me clearly.This machine setup code is: # interrupt C interrupt.
Dec 10, 2009 | Sharp AR-5316 Advanced Digital Imager...
How i can enter in service mode of sharp AR 5316 copier
On the panel display, press #, interrupt,0, interrupt keys in that order. Display will go off then enter the desired number and press Print. If the command has subcode, enter it and press Print to execute.
Nov 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
What code can i use to claer code:H4-01?it is a sharp AR-250 digital photocopier.
Press P, Interrupt, C, Interrupt keys in that order. It will ask for sim code, press 14 press print then Execute and it will clear.
Nov 12, 2009 | Sharp AR-C160 Color Copier
I want code to reset the developer ccounter
After you replace developer, press #, interrupt, c , interrupt keys in that order. Display will go off, press 42 print 01 print for developer reset. Press Interrupt key twice and press 20 print 01 print for serviceman reset. Press CA key .
Apr 19, 2009 | Sharp AR-5316 Advanced Digital Imager...
97 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
