Question about Leisure Dishwashers
The power button is crackling when i turn my Leisure DWLT65 dishwasher on. is it the power switch?
Posted by Helen Rowlands on
  • Helen Rowlands
    Helen Rowlands Feb 23, 2015
    The dishwasher however is still working and washing properly.
  • Richard C Cohen
    Richard C Cohen Oct 04, 2015
    Hello. Here is the link to the main board of your dishwasher.https://www.partmaster.co.uk/leisure/dwl...
    **Here is the link to the power button on Amazon for your unit..http://www.amazon.co.uk/Leisure-DWLT65-O...
Richard C Cohen
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Leisure Expert
  • 318 Answers
Hello. Here is the link to the power button for your unit. Most likely, the contacts inside the switch have worn out causing arcing--hence the crackling sound you heard. I would not use the washer until you get the switch repaired! If the internal contacts are not touching properly, heat will be generated and could cause the switch to melt, thereby creating a real safety hazard(I've seen this happen). Leisure DWLT65 On Off Power Switch I hope I helped you!
Posted on Oct 04, 2015
1 Related Answer
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: my leisure dwlt65 dishwasher keeps switching its self off when going till wash
see this causes and fix it. God bless you
Touchpad and Control Panel If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been have ruled out, the main control board might need to be replaced.
Posted on Sep 29, 2012
Not emping water
This is a generalize answer, but remove the bottom kick panel to manually rotate the pump motor. In general they can get locked up by objects. Locking up the pump.
May 26, 2014 | Leisure DWLT65 Dishwasher
Dishwasher will not start after being switched on- can you help
Here is the link to the power button for your dishwasher: http://www.amazon.co.uk/Leisure-DWLT65-Off-Power-Switch/dp/B00O470CVM. I hope this helps you!
Jan 03, 2014 | Leisure DWLT65 Dishwasher
Start button does not light
please follow this steps and fix it. GOD BLESS YOU
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer or Electronic control
Replace if defective (note: uncommon problem).
4. Selector switch
Read more: http://www.appliancepartspros.com/repair-help/dishwasher-repair-help.html#ixzz2aaj83j00
Jul 30, 2013 | Jenn-Air 24 in. JDB1250 Built-in...
My leisure dwlt65 dishwasher keeps switching its self off when going till wash
Sep 28, 2012 | Leisure DWLT65 Dishwasher
Fender Hot Rod Deluxe. Works great except when I turn the amp off it crackles pretty loud. It takes about 5-10 seconds for the crackle is heard. If I turn the standby switch first, then wait a minute or...
As voltages drop, electronics gets unstable as it goes down and becomes noisy... this may be the nature of this beast. Opening the standby might be the best way to avoid the problem.. Here is your schematic for service:
http://elektrotanya.com/fender_hot-rod-deluxe_sch.pdf/download.html
Scroll down to "get manual" and click to download. IGNORE other download links.
Opening the standby switch turns off power to the main amp so noise generated in the preamp will not be amplified.
Jul 25, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Sudden power failure
my swisstec tv had exactly the same problem this week march 30th and the 12 month warranty expired.....i went to skymediauk online and extended my warranty ..free for 3 months they collected it,fixed it and returned it in 46 hours
Jan 29, 2009 | LG 42LC2D 42 in. LCD HDTV
Dishwashers Logo
98 people viewed this question
Top Leisure Dishwashers Experts
Marvin
Marvin
Are you a Leisure Dishwasher Expert? Answer questions, earn points and help others
