Question about Stihl Saws
What would cause stihl ts500i cutoff saw t o die when accelerating
Posted by Danny smalley on
1 Related Answer
barterjoe
Joseph Mueller
  • 346 Answers
SOURCE: Why won't my Stihl TS350 Cutoff saw go to full
I would inspect the intake side of the piston behind the carburetor. The most common problem with cutoff saws with no water kit is fuel reversion. that is wear on the intake side of the piston that has removed over 10% of the machining marks like this:
If you do have wear like this consult a Stihl Gold certified dealer like www.arcolawn.com for parts and tools to repair it.
Good Luck
Posted on Feb 21, 2011
Stihl ts500i stalls during accelraiting.
Take back to dealer. This is a fuel injected engine.. not worth the headache sorting it yourself. It could be a problem with the electronic fuel injection. Maybe as simple as a laptop reset of the programming
Dec 16, 2013 | Stihl Saws
Ts410 stihl saw stopped working
Starting procedure for Stihl.
(cold starting)
Place cutoff saw on floor (flat clear surface).
Hold throttle in, while pushing on switch all the way down.
Hold cutoff saw firmly.
Pull starter handle until saw fires, it should then cut out.
Click the starter switch up 1 click to half choke.
Pull starter handle again until cutoff saw fires up. note: it will be reving because the trigger is loched on, (blip the throttle once) and it should go to tick over.
There should be np need to keep playing with the choke when the saw is warm. No need to lock the trigger when starting warm..
Mar 31, 2013 | Stihl Ts410 & Ts420 Cylinder & Piston Kit
Hi, My Stihl TS400 with 14"
Racing on a 2 cycle engine is usually a sign of a lean condition. It could be caused by a few different things including a bad crank seal or a torn intake manifold as some are made out of rubber. I would remove the cutter arm then pull the muffler to inspect the cylinder and piston. If they are scored it will be a costly repair.
Jul 14, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Stihl Demo saw 400 pulls with no compression
From [email protected] Hi kaqibso these saws are equipt with a decompression switch.It is located on the right side of the unit and has a red cap on it, pull out on it. Best of Luck......
May 30, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
I have a stihl st400 disc cutter & I think the pull start needs cleaning, any advice?
compressed air works well. you really need a gun with a long skinny nozzle. for example
Jan 26, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Wiring diagram for a stihl saw ST400
There is no diagram. it is a simple system the coil for the plug has a kill wire that runs up to the thumb switch.
page 31 of the service manual shows the connectors.
Make sure the wires are not rubbed through.
I am a Gold certified Tech for Stihl. Feel free to ask any other questions you might have.
Jose
link to ts400 manual
Jan 12, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Need to know belt size fo the stihl ts400 concrete cutoff saw
You should go to a Stihl dealer and ask for the belt for a TS 400 Cut Off Saw. The belt is ribbed, you should only put on a Stihl part to replace the belt and make sure the belt is under the correct tension. When you go to the Stihl dealer you can ask them to show you how to make sure the belt is under the correct amount of tension.
Aug 31, 2010 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Saws Logo
622 people viewed this question
Top Stihl Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Stihl Saw Expert? Answer questions, earn points and help others
