Televison & Video Logo
Tv wont turn on, and its making a clicking noise
It wont turn on and or do anything but make this clicking noise
Vick
    Scholar:
    New Friend:
  • 92 Answers
That usually indicates that your power supply has gone bad. The clicking sound you hear is your power supply not getting enough current to turn on your screen. Could be a simple fix as a bad capacitor but not sure? If you can pin point that problem being your power supply, it is some times cheaper to just replace the power supply board but it depends how old your TV is and if the power supply unit is available.
Posted on Feb 23, 2015
Sony Trinitron tv wont turn on no picture just makes clicking noise
Short circuited component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Tv wont stay on
there is a short, could be anything....Check amount of blinking light
Akai TV wont turn on right
this could be the power supply board
1helpful
I have an Advent Progressive Scan HD TV with pitching noise. The problem is that this TV makes a pitching noise when I turn it on, sort of like a cricket (animal) noise. Only when I turn it on is when it...
The noise is the power supply trying to raise the output voltage, but the output is shorted to ground by some cicuit. The horizontal output transistor is somewhat common problem, but could be something other. Not too hard for a shop to diagnose, but probably over $100-$150 to repair.
98 chev blazer wont start or make any noises...
Listen for a click from under the steering column when you turn the key on. If you hear no electrical click then your ignition switch could be bad. If you hear an electrical click the you starter soleniod is bad.
3helpful
Wont power on makes clicking noise
Replace any swolen capacitors in power board.
Magnavox 27m53404/17 Picture went out
Hello there, I'm having a major problem with my TV, I have called all of the local TV repair shops and they all are the same, they want money money money before they will even speak with me about the problem I'm having. This is the only TV in my entire household for a family of 4 and we desperately need the TV in working condition for our kids. I don't want to have to put out $500 for another set if I don't absolutely have to.
The Problem...
About 3-4 months ago the TV when turned on, the picture would slowly come into view and be very scrambled and before the picture would come into complete view the TV power would shut itself off, but the power light would remain on. You can hear the "Click" noise when it would shut itself off.
2-3 seconds after it 'shut itself off' then the TV would make the "Click" noise (The same noise it makes when you first turn it on), it would make the "Click" noise over and over and over again but nothing would happen. So i would turn it off and on again and change the channel rapidly until after 2-3 minutes it would come into view and work.
So we decided to leave the TV on 24 hours a day. Then today we awoke and it was off and making the "clicking" noise over and over and over again but with no picture or sound. Now it wont even turn on/off it just sits there and goes "Click, Click Click Click" and doesn't do anything.
I described the problem as best as I can. Here is the TV information and specifications...
Philips 27 Inch Tube TV
Model Number... 27PT54 3S37A
Serial Number... 78438404
105 Watts
60HZ
120V
Date Code March 2003
Now that I typed the model number there are threads everywhere people saying the same issue exactly as me, I will read them but please someone tell me is there anything I can do...
Can anyone explain exactly what is wrong with the Tv and why it's doing this?
Also, what should I expect to pay to repair it?
Any information or help would be appreciated very much.
Thanks in advance,
Anthony
Just got off the phone with certified Philips shop...they said they will repair it for $100-$130 with a $25 down payment just drop it off and he will call me when its done. Does this sound like its worth it or a rip off?
3helpful
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
2helpful
2answers
I heated up board with hair dryer through back of TV without taking back cover off. The heat was on high for approx. 5min. and was placed on right side of TV about 1/3 up from bottom.
Top Televison & Video Experts
Marvin
Marvin
