Some icing in freezer freezer is working
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You have an older unit. Some parts are no longer available.
There are 3 possible component failures:
1.) Refrigerator Adaptive Defrost Control Board - This has the most probability for your problem.
Substitution: 61005988 Cost $78.00
This is located in your fresh food section control housing. You must drop the control housing to access it.
2.) Defrost Heater - This component is located in your freezer section. You must remove the back wall to access the heater.
The back wall on your model has slots and screws that are both difficult to remove and more difficult to replace. Even harder is the string the wires up through the cooling coil without cutting your self on the razor sharp fins on the cooling coil.
Substitution: 61006199 Cost: $48.00
3.) Refrigerator Evaporator Fan Motor - This too is behind the back freezer wall which is difficult to remove and re-install.
Part #: 61005339 Cost: $106.00
Ok, what do we do?
A.) If you know someone who is above average mechanically inclined you may decide to replace the components.
B.) If I were still working for Sears Homes Services, I would leave you with a bill for about $450.00 or more.
Normally a refrigerator should last you 20-30 years.
Your unit is old. You are at the point that components have reached there life cycle. You repair this problem, then 6 month to a year another component is going to fail.
My I suggest; go into the internet and search for Sears Outlet Store (Scratch and Dent). You can save several hundred dollars and will get a one year warrantee.
Go simple. I have a 23 year old Kitchen Aide top freezer.
Stay away from Samsung and LG units unless you want trouble.
Stay away from bottom or drawer freezers. They are high maintenance.
Stay away from units that have either ice makers on the door or ice buckets on the door. When you open the freezer door, warm air from the room will cause block icing. Ice makers and ice buckets belong in the freezer.
With icing in freezer, what do you mean?
which part of freezer is icing? the back panel? or do see snow flake type of icing somewhere else also?
check air supply vent in the Fresh Food Section to see if there is any airflow...if there isn't then open the freezer door and check the same vent again...if there is airflow now, then you probably have a defrost problem, which could be the heater, def.terminator, or timer/control board.
SOURCE: Refrigerator part does not get cold
again, defrost heater problem. 3 things... 1 ..defrost heater itself, could be broken, 2...thermodisc, could be open also, 3...electronic timer or electronic heater controller malfunctioning...may need an expert to trace all 3 items.
SOURCE: Maytag refrigerator cooling probelm
Defrost the fridge, take everything out of freezer and turn off for at least a day, check the drain is clear after defrosted and try again, if it happens again you may need a new defrost heater of timer.
SOURCE: Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
SOURCE: freezer working - refrigerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
dtiurt7
SOURCE: freezer is very cold, refrigerator not cooling on Maytag side-by-
heatman101
s
Replacement parts can be
purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
repairclinic.com
partsselect.com
directly.
in refrigerator?
refrigerator?
These will help.
Thanks,.
repairclinic.com
partsselect.com
directly.
in refrigerator?
refrigerator?
These will help.
Thanks,.
repairclinic.com
partsselect.com
directly.
in refrigerator?
refrigerator?
These will help.
Thanks,.
directly.
in refrigerator?
refrigerator?
These will help.
Thanks,.
directly.
in refrigerator?
refrigerator?
These will help.
Thanks,.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
