Question about Sharp AR-F152 Fax
Can't get Fax Confirmation page to print
I go into special modes for faxes and select to "always print" transaction reports. However, the printer will still only print out faxes that do not go through. It will not print a transaction report for faxes that do go through.
Any way to make transaction reports print for all outgoing faxes, and make it stick?
Posted by darin999 on
Anonymous
  • 62 Answers
What model brand name something!!!!!!
Posted on Mar 07, 2008
How would i get the fax report
from the user manual:
The default fax confirmation setting is Every Error. This means that your
HP Officejet prints a report only if there is a problem with sending or receiving a fax. A confirmation message indicating whether an item was successfully sent appears briefly on the front panel display after each transaction. To have a confirmation printed for every fax, follow these instructions.
1 Press Setup.
2 Press 1, then press 1.
This selects Print Report and then selects Automatic Reports Setup.
3 Press direction right button until Every Fax appears in the second line of the display, and then press OK.
The HP Officejet will print a confirmation report every time you send a fax informing you whether the fax was sent successfully or not.
Enjoy
Christopher
May 21, 2012 | HP OfficeJet 4255 All-In-One InkJet...
Have Brother MFC-7840W Printer/Fax How do you set the fax to print off confirmation reports
Hi there!
For you to setup the confirmation here's what you can do:
-Press Menu/set 2,4,1 -Press the Up or Down arrow key and select ON you can select On+Image to get a confirmation with the image of the document that u fax. -Press Menu/set to confirm -Press Stop/exit
To print the confirmation page for your last transaction just press Reports and press the up or down arrow key to select Transmission
Hope this helps! Thanks!
Jun 03, 2011 | Brother MFC 7840W Printer
HOW DO I PRINT FAX CONFIRMATION REPORTS PLEASE
Touch the [Image Send Settings] key, the [Fax Settings] key, and then the [Fax Default Settings] key to configure the settings.
Go to Transaction Report Print Select
Setting
These settings are used to set the conditions for printing
transaction reports for single transmissions, broadcast
transmissions, receptions, and confidential receptions.
For each type of operation, touch the key of the desired
condition.
May 16, 2011 | Sharp MX-2300N Color Copier
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
How do i get a report of the fax i sent?
Follow the steps to setup the Fax sent confirmation report.
  1. Press Setup (c01461502.gif ).
  2. Press the right arrow button (c01185072.jpg ) to select Print Report , and then press OK .
  3. Press the right arrow button (c01185072.jpg ) to select one of the following options:
    • On Fax Send: Print a confirmation page every time you send a fax.
  4. Press OK .
Other confirmation reports in the same menu are :
  • On Fax Receive: Print a confirmation page every time you receive a fax.
  • Send & Receive: Print a confirmation page every time you send or receive a fax.
Hope this is helpful
Thank you for contacting FixYa.
*Rating and comments invited on this solution
Nov 11, 2010 | HP OfficeJet J4580 All-In-One Laser...
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
Transaction Report that includes portion of the fax in AR-5127, not only in error - is it possible?
In fax mode, touch the [SPECIAL MODES]
key.
Touch the [TRANSACTION REPORT] key.
If you want the transaction report to print regardless
of whether the transmission succeeds or fails, touch
the [ALWAYS PRINT] key.
Touch [PRINT ORIGINAL IMAGE] checkbox
Touch the outer [OK] key.
Oct 20, 2010 | Sharp AR-M237 Copier
What button do I press to generate a Fax report - this is not always generated automatically.
Sounds like your Fax Options are set to print on error only. If you want to have both confirmations and error pages do the following:
1 Press Menu until “Fax Setup” appears on the top line of the display. Press Enter.
2 Use the scroll button to find MSG Confirm. Press enter.
3 It may be selected to On-Err. Use the scroll arrow buttons to get to On. Press Enter.
4 To return to Standby mode, press Stop/Clear.
This should make your fax print out a confirmation on a successful or failure transmit of your fax.
If you want to print out the last few sent or receive faxes:
Printing a Report
1 Press Menu until “Reports” appears on the top line of the display.
2 Press the scroll arrow buttons to display the report or list you want to print on the bottom line.
•Phone Book: Phonebook list •Sent Report: Sent fax report •RCV Report: Received fax report •System Data: System data list •Scheduled Jobs: Scheduled job information •MSG Confirm: Message confirmation •Junk Fax List: Junk fax number list
3 Press Enter. The selected information prints out.
You can find your manual in English by clicking here.
------------------------------------------------------ Please rate this post if it helps you! :)
Dec 08, 2009 | Samsung SCX 4521F All-In-One Laser Printer
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Sharp AR-F152 Fax Logo
458 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
