Details are that he and I used to be able to text each other with our iPhones and during the past week we cannot. I get texts and send texts to others, but all of a sudden my phone won't allow his texts and vice versa. My settings seem right.
Turning off iMessage will most likely fix it. Both of you check that it's turned off.
First, make sure one of you didn't somehow accidentally block the other person on your phone (Settings > Messages > Blocked)
Second, try doing a hard reset (hold home button and lock button at the same time until the apple logo appears on the screen).
If that doesn't work, try turning off iMessage (Settings > Messages) and then turning it back on.
If neither of those options work, it's likely an issue with your cellular provider. Talk to them. You might just need to get a new SIM card.
SOURCE: Sometimes after exchanging 2-3 text messages on my
You could try resetting all settings if you haven't already. This option is located under Settings >General > Reset.
If that doesn't do the trick, it sounds likely you would want to restore
your iPhone, setting it up as a new iPhone. Before doing so just be
sure to sync your contacts, calendars, camera roll photos, and transfer
purchases to your computer. Essentially, you just want to make a back up
of your data.
More information on the restore process: http://support.apple.com/kb/HT1414
Hope this helps,
