Question about VIA P4PB 400 (P4PB 400-FL) Motherboard
Hello , i need a manual for moterboard p4pb 400 with via chipset thanks
Need a manual
Posted by cristian doroftei on
Lars Olsson
    Brigadier General:
  • VIA Master
  • 3,400 Answers
Cant find where to connect power switch on a via p4pb400 motherboard
use this link and download manual
http://www.viaembedded.com/en/products/boards/others/p4pb_400.jsp
Jan 12, 2014 | VIA P4PB 400 (P4PB 400-FL) Motherboard
Not conectered internet
Hello the drivers can be downloaded here:
http://www.viaembedded.com/en/products/boards/others/p4pb_400.jsp#drivers
Please unzip the lan file, before you install.
Good luck
Feb 24, 2013 | VIA P4PB 400 (P4PB 400-FL) Motherboard
Where can I buy one ?
Ebay, in used condition i would suspect
Aug 11, 2012 | VIA P4PB 400 (P4PB 400-FL) Motherboard
Can you run Windows 7 on a P4PB FL-400 motherboard?
From what I've read, apparently you can, but you will need to use this driver for your sound driver:
http://www.viaarena.com/Driver/vinyl_v700b.zip
May 30, 2012 | Computers & Internet
I have a new 320Gb hard drive, but it is not being recognized by my via p4pb 400 motherboard. Is this a bios upgrade issue?
At most of the cases like yours the problem is not at bios upgrade but at bios settings. If your hard disk is SATA you have to enable the SATA controller and make the necessary setting at the bios. Is your hard disk SATA or IDE? Post me back to provide you more details.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Nov 07, 2010 | VIA P4PB 400 (P4PB 400-FL) Motherboard
I have a via P4PB 400 fl mobo and I need to know the way that the front panel connections go on the pins.please help i cant seem to find a manual for it anywhere.THANK YOU.
You can view the front panel connections you asked for here:
In case you'd like the whole manual, here is the link for you to download it.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 28, 2010 | VIA P4PB 400 (P4PB 400-FL) Motherboard
Support for CPU SL7X5 - Bios wont recognize and/or not boot. CpU microde update which & how becose i suspect that stepping is problem ! But Best Brand 533FSB CPU !
It is possible that your mobo (P4PB) is set to support your old processor ONLY. You can follow this guide and set your FSB support to 'AUTO' based on the pin/DIP switch illustration as provided:
Hope this helps out.
Jun 09, 2009 | VIA P4PB 400 (P4PB 400-FL) Motherboard
VIA P4PB 400 (P4PB 400-FL) Motherboard Logo
166 people viewed this question
Top VIA Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Jay Green
Level 1 Expert
Atiq
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
