Question about Bosch Washing Machines
My Bosch Maxx does take water in but the wash cycle would not start
I hav a Bosch Maxx WFL 2060. I did put detergent in and the water does go into the machine, but the machine would not start its wash cycle. I did clean the water inlet.
Posted by Mariet Landman on
tom cassidy
    Genius:
  • Bosch Master
  • 1,585 Answers
Check door inter lock
Posted on Mar 01, 2015
5 Related Answers
Anonymous
  • 1294 Answers
SOURCE: Goes through washing cycle but doesn't dissolve the tablets or cleans the clothes.
Clean out your outlet filter; this is to be done regularly once a month, depending on your usage. Re your tablets not disolving, try using front loading washing powder. Also refer to your manual..........
Posted on Jun 11, 2007
shaun taylor
  • 1527 Answers
SOURCE: bosch maxx wfl 1300 washing machine that wont start.
hello could be brushes on the motor. there are 2 black clips that sit on the motor after time these whare down just slide them out and slide new ones in good luck
shaun
Posted on Jul 21, 2009
Anonymous
  • 228 Answers
SOURCE: The water does not cutoff during rinse cycles
pressure chamber blocked with soap depists scale etc will need removing for service and cleaning partial strip down required.
Posted on Feb 17, 2010
tony2155
Tony Houde
  • 64 Answers
SOURCE: washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
Posted on Mar 28, 2010
Anonymous
SOURCE: Bosch Maxx 5 Washing machine will not wash, drum does not spin.
maxx5, error F63
Posted on Dec 14, 2010
Bosch Axxis WFL 2060 Front Load Washer - DRUM DOESN'T CYCLE
This seems to be a fault with the program controller unit or the water level sensor. The program does not advance further after the inlet is filled but operates the drain to exit water. Now the water level sensor must be checked as if this is not working in the stipulated time it will drain out. Also unless the water level sensor contacts on reaching of set level the motor must start.http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Mar 14, 2012 | Washing Machines
The water does not cutoff during rinse cycles on the rinse plus and normal wash programmes on my Bosch Maxx WFL 2060 but works fine on quick wash programme
Feb 14, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL2060 stopped working on a wash cycle. The first time I used liquid HE detergent. I am sure I put too much in and the interior foamed up, the detergent tray foamed up and came out underneath...
water in base after overfoaming has leak detection if you can tip machine back this water will run onto floor allowing unit to rest, make sure you put down some rags towel etc to trap water there will be up to a pint of water.
Jan 29, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL 2061 motor starts running and then stops
Hi ! I have problem with my Bosch Washer wfl 2061 .. It was running till stoped to
realease drain water out... But no drain water come out.. I have checked drain water host... Nothing thaere.. Water was still in the drum Tank... Whoever knows this problem , please kindly suggest or help me to do something.. Thanks.. Peace [email protected] , [email protected]
Nov 28, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing instructions
My book says for the Axxis WFL 2050/WFL 2060 : from the left while looking at it from the front: detergent for wash, stain remover, middle: fabric softener, fabric conditioner, right one: detergent for soaking agent. (Do not use chlorice bleach in this wasking machine).
Oct 11, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL 2060
connect at random. put on a rinse cycle. if cold water comes in then pipes are correct. if hot water comes in then pipes are wrong way round and just swap them
Sep 13, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washer only seems to work on 40 degree cycle
check to see if this model has 2 water inlet hoses
if there is 2 only 1 may be used and is connected to hot tap thus only letting in hot water when machine requires water
Jan 03, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
Top Bosch Washing Machines Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
